06-06-2009, 11:56 PM | #57 |
Boost Is Your Friend
Drives: 2016 Hyper Blue 1SS Camaro Join Date: Oct 2008
they said they checked the whole system to make sure. But they said they need to replace the ecm. That is also wat the book says to do
06-07-2009, 12:40 AM | #58 |
Drives: 2016 Camaro 1LT M6 Join Date: Aug 2008
You really cant check the KR sensors unless you look at the scans at WOT. How much knock was the dyno saying you were getting?
If the ECM is pulling 15 degrees its the KR sensors telling it to do so. |
06-07-2009, 12:58 AM | #59 |
Drives: 00 Blazer Join Date: Aug 2008
Could be contaminated fuel like some water.
What fuel is in it btw? Just some super with no additives? To low or high can cause that sensor or bad fuel. edit: Also the computer does a self diagnostic and if it was bad it would tell you or not work. So putting another is not gonna fix this. They probably replaced the sensor. Which is why I suspect fuel quality. The car itself has no problem. Just bad juice... |
06-07-2009, 03:26 AM | #60 |
Helping Build America
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD Join Date: Aug 2008
This is quite curious.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
06-07-2009, 06:24 PM | #61 | |
06-07-2009, 07:03 PM | #62 |
Drives: Broken Join Date: May 2009
Would be curious how they checked the the knock sensor. Its throwing that code for a reason, if you follow the troublshooting guide for any code it will eventually lead you to a faulty ecm if everything checks out. If you get to that point, start over, you missed something. Obviously they are missing something if they have put three computers in it and all say the same thing.
06-07-2009, 07:56 PM | #63 | |
06-07-2009, 11:13 PM | #64 |
What codes did the first ones say?
06-08-2009, 01:38 PM | #65 |
OK, my computer in my car gave knock sensor codes, second computer didnt even take any programming (didnt even upload anything), third one gave a RAM code (what ever that means), but didnt show the knock sensor codes anymore. So they are getting a computer that has the same model number from the production line in Canada now.
06-09-2009, 07:34 PM | #66 |
hopefully should be fixed tomorrow
06-09-2009, 09:03 PM | #67 |
Drives: Black 2SS RS M6 Join Date: May 2009
Very sorry to hear you are having issues. I'm sure you are anxious to drive and not diagnose a mechanical problem. I will stayed tuned to check how this progresses. So far alot of good suggestions: fuel, KR sensors, electrical gremlin, and more....all good. Hang in this will get solved.
06-11-2009, 04:14 AM | #68 |
Drives: 2013 ZL1 # 2195 Join Date: Jun 2009
Any Updates?
06-15-2009, 10:53 PM | #69 |
Problem fixed!!!! Back to Techco to get screwed! It now dynos at 380 rwhp and 385 ftlb. torque
The ECM was faulty and my dealership changed it out. What took so long was the engineers took a computer off the production line, tested on a car, tuned it a little better, and sent it out. |
06-16-2009, 06:08 AM | #70 |
Drives: Not a Camaro :( Join Date: May 2009
Grats man!! Glad this got cleared up. To be honest, I'm a little surprised it was the computer. I work in electronics and when a part goes bad several times, it usually ends up being the wiring or some other random part that you'd never think of. Enjoy the new puter and enjoy the ride.
Similar Threads | ||||
What is the difference between a Sports car and a Muscle car (whats your opinion) | Camaro Man | 5th Gen Camaro SS LS LT General Discussions | 33 | 02-15-2011 11:15 PM |
Pedders Suspension Benchmark Track Testing and New Jersey Track Day | Info@PeddersUSA.com | USA - NY / NJ / PA | 35 | 10-26-2009 05:20 PM |
The Camaro, what it has come to mean for me | Number 3 | 5th Gen Camaro SS LS LT General Discussions | 23 | 04-13-2009 09:31 PM |
From Fbodfather - Setting the record straight. | Moose | General Automotive + Other Cars Discussion | 27 | 12-10-2008 12:25 PM |
Voice Your Comments/Suggestions/Input for Focus Group on 2010 Camaro | Mr. Wyndham | 5th Gen Camaro SS LS LT General Discussions | 236 | 04-22-2008 12:43 AM |
