09-14-2017, 09:56 PM | #715 | |
Drives: 2014 Camaro 1LE Join Date: Jul 2017
09-15-2017, 05:39 AM | #716 |
Drives: 2015 Z/22 Join Date: Aug 2015
Elongating the radius rod bolt hole at the subframe like GM should have done (!), by drilling/grinding it out will allow you to gain more caster - this is not required but if you're getting more into handling/cornering it is something to consider. Buying/making "caster lock" washers (such as the ones Pete sells) is also a good idea to keep the caster bolts in place as they will now have the potential to move around in the larger hole.
09-15-2017, 01:52 PM | #717 | |
Drives: 2013 Camaro 2SS/RS Join Date: Apr 2015
I set it to full soft and drove it some (did some tight u turns at speed), it does seem better however I probably won't know for sure until the next autocross event. So you don't think my toe settings (.19 front, - .1 rear) are contributing to the under steer, right? Appreciate the help! |
09-15-2017, 03:28 PM | #718 | |
Drives: Camaro Justice Join Date: Jun 2007
If you care nothing about tire life: Front Camber -2.5 Toe OUT 0.50 Total Toe OUT 1.00 Rear Camber -1.75 Toe IN 0.08 Total Toe IN 0.16 We can add a degree of Caster with JPSS Caster Locks and 1.5 to 2 degrees of SAI with JPSS bolt in SAI Plates. It all depends on your tolerance for tire wear and mod budget. Do you know what makes a car go fast? Some things never change. |
09-15-2017, 03:47 PM | #719 | ||
09-15-2017, 03:57 PM | #720 | |
You can adjust the numbers relative to each other for improved tire life, but you already knew that. I wouldn't go quite so far with the rear camber without a smaller front or larger rear sway bar. |
09-18-2017, 05:12 PM | #721 |
I tried to get my 20141LE aligned to Petes aggressive street specs and the shop said the car does not have the ability to adjust the camber on the front. I disagreed based on what I have seen here. I even brought in the instructions from Pete. Any help would be greatly appreciated. I attached the alignmentsheet. |
09-18-2017, 07:25 PM | #722 |
First step would be to go to a different shop . The front camber is adjusted by loosening the two nuts/bolts at the bottom of the strut - one hole is elongated to allow the strut to pivot on the knuckle. There is also a threaded hole in the knuckle that you may have seen in Pete's guide - this allows for fine adjustment of camber, and such a bolt can be ordered from Pete (or probably various hardware shops if you know the thread pitch and stuff which I believe is mentioned in Pete's guide as well).
09-19-2017, 08:20 PM | #723 |
Drives: 2012 2LT RS White Born: 11/10/11 Join Date: Nov 2011
I'm going to look through this thread for my answer, but in case Pete or anyone else can point me in the right direction before I can get there I'll pose my question. 2012 Camaro V6 stock suspension other than upgraded front and rear sway bars. I did what I think was an aggressive street alignment for my last track day:
Fr camber -1.00 per side Fr Toe 0.00 Rear Camber -.5 Rear toe .12 Total Toe .24 I"m willing to go further with the alignment for the track since Tires Plus will do it right before the event and then revert me back right afterwards. So what specs do they need to shoot for? I'm running 20X10 285/35-20's.
*Grey Hockey Stripes; Heritage Grill; GM GFX - Unpainted Argent Gray; GM Dovetail Spoiler; Rivercity Creations custom painted rear bowtie, RS & Taillight Bezels; MRR M017 Graphite Wheels; Nitto NT555 G2; ACS 4Teen Heat Extractor
*RX Catch Can;CAI; MF Exhaust; VMAX CNC Spiral Ported TB; Overkill Stage 1 Supercharger System; Hotchkis Comp Sway Bar Set w/ End Links, Cadillac CTSV 4 Piston Brembos on all corners with SS Black Hat Rotors Youtube Channel - HPDE Driving Videos https://www.youtube.com/channel/UCpO...8aw6hgX3O1Uh7A Last edited by Silent...; 09-19-2017 at 08:59 PM. |
09-20-2017, 07:29 AM | #724 | |
Try this with your well balanced V6. Front Camber -2.5 or as close as you can get Toe OUT 0.50 Total TOE OUT 1.00 Rear Camber -1.75 maintain a similar ratio if you can't get -2.5 up front Toe IN 0.05 Total Toe IN 0.10 Let us know how she feels. |
09-20-2017, 11:49 AM | #725 |
Pete. Thanks so you think about my alignment I posted above for autocross?
09-20-2017, 01:09 PM | #726 |
09-20-2017, 04:54 PM | #727 |
Thanks Pete. I'll be at Sebring International Sept 30 and Oct 1 for the third time this year. I'll let you know.
*RX Catch Can;CAI; MF Exhaust; VMAX CNC Spiral Ported TB; Overkill Stage 1 Supercharger System; Hotchkis Comp Sway Bar Set w/ End Links, Cadillac CTSV 4 Piston Brembos on all corners with SS Black Hat Rotors Youtube Channel - HPDE Driving Videos https://www.youtube.com/channel/UCpO...8aw6hgX3O1Uh7A |
09-20-2017, 07:03 PM | #728 |
Similar Threads | ||||
Definitive GT500 Thread | garagelogic | Chevy Camaro vs... | 98 | 02-12-2010 01:14 PM |
Lets start a Tire Specific Thread here, sizes, brands, specs and other usefull info. | 55Designs | Wheels and Tires Talk Sponsored by The Tire Rack | 0 | 12-20-2009 07:58 PM |
Suggestion: Explanation to thread starters for their threads being locked? | colin911 | Site Related Announcements / Suggestions / Feedback / Questions | 2 | 12-06-2009 10:25 PM |
Dealer Praise Thread (Not an Idiot!) | RPO_Z28 | Camaro Price | Ordering | Tracking | Dealers Discussions | 84 | 06-25-2009 01:00 AM |
prices thread | nimnels | 5th Gen Camaro SS LS LT General Discussions | 1 | 05-02-2009 06:47 PM |
