12-27-2016, 07:33 AM | #71 | ||
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously) |
12-27-2016, 09:31 AM | #72 | |
"Lohla"
OG Trans and Diff but all else is upgraded. Twins bring wins ;-)
12-27-2016, 10:50 AM | #73 |
Smarter in some respects, probably.
But it's no better at reading NCSD's mind from a couple of feet away than I am from the other side of the continent. Norm
12-27-2016, 12:20 PM | #74 |
Drives: brz... Join Date: Dec 2016
I find it tough to believe that your asking this question while having experience racing at one of the highest levels of any motorsport. If you are trying to be fast, you want the engine to be making the most possible power and that requires rpms of that order.
12-27-2016, 03:48 PM | #75 | |
Drives: 2014 2LS (traded in) 2015 1SS 1LE Join Date: Apr 2015
12-27-2016, 06:13 PM | #76 |
The A8 gear ratios are pretty closely spaced once you're up to 3rd (which is probably the case nearly all of the time at most tracks), so the revs aren't going to drop very far even after an upshift. Plus, if the torque converter is not locked up, the revs will run a little higher due to rpm loss across the TC.
Gear ratios, with the 1LE gears shown for comparison. The adjacent gear spacing in the 8A is closer everywhere. This brings the minimum revs used up, where you'd rather be short-shifting and dropping the max revs instead. 8A - - - - 1LE 4.56 2.97 - - - 2.66 2.08 - - - 1.69 - - - 1.78 1.27 - - - 1.30 1.00 - - - 1.00 0.85 - - - 0.74 0.65 - - - 0.50 Apparently, track mode assumes something like a 9/10ths or better level of driver seriousness is in place all the time, and it can't comprehend a driver wanting to dial it back from that. IOW, right now it expects you to be driving your Camaro harder than you want to. Norm
01-29-2017, 03:31 PM | #77 | |
Drives: 2021 ZL1 6MT Join Date: Jan 2017
Had no problems at the track
The car performed perfectly. Transmission kept the rpm's where I needed them all of the time in auto mode.
Michelin Pilot Super Sports, Raybestos ST43 pads on the front, cooling kit installed, Mobil 1 10w40 High Mileage full synthetic, mixed the fuel 50/50 with high octane unleaded
01-31-2017, 12:48 AM | #78 | |
Oil temps got high but well below the red lines. I did not count the increments or record the values. I visited the dealer prior to going and expressed my concern about tracking the car and having it prepped properly, warranty etc... I was told to go have fun and if the tranny broke they would put in a new one. REV IT UP!
