#1093 |
![]() Drives: 2012 Camaro Convertable rs/ss Join Date: Jun 2011
new 2012 replacement is in
Guys and Gals,
My replacement car is in (Straight trade with not cost to me, dealer did not want to lemon it out for some reason, bad press I bet). New 2012 looks the same but I really like the new 2012 options. Foot well lighting is cool. Also the Manual Transmission is the only way to go. Only got 280 miles on it so far with 150 with the top down. No rub marks. Sorry that I won't be able to report more until the spring, it is going into storage next week. But I will be replacing the screws with flat screwable rivets from Ace Hardware. Also there is no tape at all on the rails or any other place. Build date last week of Sept. Fingers XX, and praying of no other problems. ![]() |
#1094 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS LS3/6M Litho#190 Join Date: May 2010
![]() 2011 Chevrolet Camaro | Camaro (VIN F) Service Manual | Document ID: 2734604 #PIC5449A: Convertible Roof Cloth Sags At Rear / Large Gap Between Number 5 Bow And Rear Panel - (Oct 27, 2011) ![]() Subject:Convertible Roof Cloth Sags At Rear / Large Gap Between Number 5 Bow And Rear Panel Models:2011 - 2012 Chevrolet Camaro Convertible This PI was superseded to update model and model years. Please discard PIC5449. The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI. Condition/Concern: Customers concern that there is a large gap between the #5 bow and the rear "tulip" panel when the top is closed and latched. This may cause a sag in the cloth top material, causing the appearance of a loose fit. ![]() ![]() ![]() ![]() Recommendation/Instructions: This condition may have been caused by the topics discussed in PI0378 and/or PI0406. Review the latest revision of PI0378 and PI0406. Replace the #5 bow following repair procedures in SI. There are tips/tricks mentioned in GM Training videos/training courses for the Camaro Convertible located on the GM Training website. It is recommended to view these training items prior to beginning the repair. Immediately following replacement of the 5 bow assembly, or any time the top assembly has been removed from the vehicle, and prior to cycling the top for the first time; it is necessary to follow the latest version of PI0406 to ensure that the Folding Top Quarter Outer Drain Panel (water management bag) is not interfering with the top assembly. Failure to do this may result in damage to the #5 bow. In the April 2011 Emerging Issues video, there is a segment on inspection and finessing of the Folding Top Quarter Outer Drain Panel (water management bag). Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information. ![]() © 2011 General Motors. All rights reserved.
![]() '11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned Proud Litho owner #190 - Homecoming Litho #120 '15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA |
#1095 |
![]() 2011 Chevrolet Camaro | Camaro (VIN F) Service Manual | Document ID: 2726338 #11-08-67-001A: Convertible Top Cloth Spots/Indentations or Damage Between #1 and #2 Bow (Follow Procedures Outlined Below) - (Oct 19, 2011) ![]() Subject:Convertible Top Cloth Spots/Indentations or Damage Between #1 and #2 Bow (Follow Procedures Outlined Below) Models: 2011-2012 Chevrolet Camaro Convertible This bulletin is being revised to add the 2012 model year. Please discard Corporate Bulletin Number 11-08-67-001 (Section 08 – Body and Accessories). Condition #1 ![]() ![]() Some customers may comment on seeing a cut or tear in the convertible top cover between the #1 and #2 bow, on either side of the vehicle. Cause #1 ![]() ![]() Important: Ensure the retaining screws are installed in the proper location. The graphic above shows the correct (1) and incorrect (2) locations for the screws ![]() ![]() Note: In the graphic above, the black plastic corner support has been painted white to make it more visible. This condition may be the result of a headliner that was incorrectly installed, which allows the plastic corner support (stitched into the corner of the headliner) to create a pressure point on the convertible top cloth when in the stowed position. Condition #2 ![]() ![]() Some customers may comment that they see spots or indentations in the convertible top cover between the #1 and #2 bow, on either side of the vehicle. Cause #2 This condition may be caused by the convertible top cover material being pinched between the top flipper door bracket and the top frame. Correction for Condition #1 and #2 Both conditions will be repaired in the same manner. Referring to the Parts Information below, contact the Warranty Parts Center (WPC) to order tape P/N WPC♦#611 and repair the condition following the steps below: Important: If the convertible top has a depression in the top cover material, and the cloth is NOT cut, DO NOT replace the top cover. The depressions can be removed by washing the top cover using a mild soap and a soft brush, to loosen the material. If, however, the top cover is cut or has material threads showing, it will be necessary to replace the top cover. Mark the area of the cut with a paint pen. The top cover will be subject for return to the GM Warranty Parts Center (WPC). ![]() ![]() 1. Cycle the convertible top to a mid-open position. To protect against items falling into the interior of the quarter panel, place a shop towel over the opening in the quarter trim. ![]() ![]() 2. Remove the two screws (1) retaining the headliner corner support to the front flipper door bracket and position the headliner away from the bracket. ![]() ![]() ![]() ![]() Note: In the graphic example above, the flipper door bracket was shown removed from the vehicle and marked for illustration purposes only. 3. Using paint or a wax pencil, mark the lower section of the flipper door bracket for material to be removed as shown above. ![]() ![]() 4. Use snips to trim away the marked section of bracket material. ![]() ![]() 5. Remove all sharp edges on the bracket with a file or sandpaper. ![]() ![]() 6. Using paint or a wax pencil, mark the corner support for material to be removed, as shown in the graphic above. Note: Because of build variation of the convertible top, it may sometimes be necessary to cut the lower stitching with a razor blade or Exacto knife in order to access the lower edge of the headliner corner support. 7. Use snips to trim away the lower section of the material on the support. 8. Again, remove all sharp edges with a file or sandpaper. 9. Reposition the corner support to the flipper door bracket and install the retaining screws. ![]() ![]() 10. Put a dab of Kent High Tech™ Clear Seam Sealer*, P/N 10200, or equivalent, to seal the edge of the threads (1) where the stitching was cut. ![]() ![]() 11. Apply the protective tape obtained from the WPC to the mid-roof linkage (shown above) on BOTH sides of the convertible top. 11.1For each side, cut a 50.8♦mm (2♦in) length and a 25.4♦mm (1♦in) length from the P/N WPC♦#611 tape. ![]() ![]() 11.2Apply the longer piece of tape to the larger mid-roof link (1), on each side 11.3 Apply the shorter piece of tape to the smaller mid-roof link (2), on each side 12. Cycle the top and verify proper operation. * We believe this source and their products to be reliable. There may be additional manufacturers of such products/materials. General Motors does not endorse, indicate any preference for, or assume any responsibility for the products or material from this firm or for any such items that may be available from other sources.Warranty Information * This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide. Parts Information To obtain the tape, fax the form included in this bulletin to the GM Warranty Parts Center (WPC). Request WPC♦#611 for the tape. IMPORTANT NOTE WHEN PRINTING THIS FORM: If the form prints out on two pages, make certain you fax BOTH pages so that the WPC receives all the needed information. Missing information will delay or prevent the part from being shipped. Parts Request Form – Warranty Parts Center Use this form ONLY for U.S. and Canadian Dealers. Export markets and Mexico Dealers must contact their regional Technical Assistance Center for assistance. IMPORTANT NOTE WHEN PRINTING THIS FORM: If the form prints out on two pages, make certain you fax BOTH pages so that the WPC receives all the needed information. Missing information will delay or prevent the part from being shipped. GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information. ![]()
![]() '11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned Proud Litho owner #190 - Homecoming Litho #120 '15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA Last edited by MS3DALE; 04-28-2012 at 03:14 PM. |
#1096 |
Treasure Coast Camaro 5
Drives: 19 2SS vert, Mosaic Blk, A10 Join Date: Feb 2009
Sooooo ... what's changed? Am I completely missing something from the Sept TSB????
#1097 |
![]() ![]() ![]() ![]() ![]() Drives: 2011 SS/RS VERT Join Date: Mar 2010
#1098 |
Glad its not just me!
Got all excited when I read a new TSB, trimming, etc... but looks like the same thing. Hopefully I'll get some clarification on this Wednesday
#1099 |
![]() Drives: 2011 2LT RS Convertible Camaro Join Date: Jul 2011
Ugh. I had my car in the shop today for the 4th time for the PDIM not working correctly, and mentioned the rub marks on my top. Now they've ordered a new top. I almost wish I hadn't said anything... Seems like everyone who's gotten a new top has regretted it... :(
2011 "Victory Red" Camaro 2LT Convertible RS • Custom Painted "Corvette Black" Racing Stripes • SLP Rear Quarter Gill Graphics • Painted Engine Cover • EmblemPros Underhood Bowtie • River City Creations Custom Painted Bowties • Vararam Intake • JDP V6 VMAX Ported Throttle Body • Hypertech Max Energy Programming • ******** Large Sub Enclosure • 10" DC Sound Labs Level Four Subwoofer • Sundown SAX-1200d Amp • 2SSRS Rear View Backup Camera Kit
#1100 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 RJT 2LT/RS Convertible Join Date: Nov 2009
Dropped her off the morning for top adjustment and water management replacement. Hoping this will be the last.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
#1101 |
Got the car back tonight for the water management and top replacement. Everything looks good, now I just have to hope for a nice day to put the top down to see if the rub marks come back. All TSBs were implemented and the top inspected by the local GM rep. Keeping my fingers crossed !
#1102 | |
![]() Drives: camaro Join Date: Dec 2010
#1103 |
![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2LT RS Convertible Join Date: Jul 2011
THAT'S out-freaking-standing! Thanks for sharing!
Summit White Black Leather 3 Pedals Build Date: 06/27/2011 Purchased: 07/30/2011 Title Received: 08/15/2011 1984 Camaro (3rd Gen.): Traded: 1987 "Meet the new boss. Same as the old boss." |
#1104 |
"Catharine"
Drives: '11 2SS/RS LS-3 IOM/IO vert Join Date: Mar 2011
WOW!!!
#1105 | |
Needs more Horsepower
Drives: GMC Sonoma, Equinox LT AWD Join Date: Apr 2009
The one on 10/27/11 is for the gap betwen the #5 bow and the rear panel not the rub marks. #PIC5449A: Convertible Roof Cloth Sags At Rear / Large Gap Between Number 5 Bow And Rear Panel - (Oct 27, 2011) This replaces PIC5449. ![]()
*** Failed cc sanity check. Bailing out! ***
#1106 |
![]() Drives: "11 2SS/RS VR vert BG/BG SW stripes Join Date: Nov 2010
Thanks MS3DALE !
I would like to thank MS3DALE for posting the bulletin for the #5 bow problem at the exact right time. After 8 months of ownership, all of a sudden, the top didn't sit flush in the back deck anymore. Took it to the dealer and was told that GM says there is a three week backorder on the #5 bow because "apparently, it's a pretty widespread problem". I asked the dealer if the top was going to have to be removed and he said yes, but he trusted his guys to do it right....OH BOY! I got a semi-fix for my rub marks from this dealer after two trys a few months ago when they trimmed the offending bracket. It decreased that problem but I still have the marks. I was gonna wait till they came out with a tried and true fix but figured while its in there and they are dickin with the roof they might as well try the half a dozen fixes that GM has shat out. Thankfully, it's gettin chilly
Washing/Detailing for Newbies | MRK III Z28 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 125 | 02-05-2024 09:55 PM |
Top Gear - Killing a toyota part 1, 2, and 3 | Crowley | General Automotive + Other Cars Discussion | 11 | 07-01-2011 12:38 PM |
Redline Motorsports HTR 850R wins top 10 Mothers Choice Award at SEMA | DeNooyerPerformance | 5th Gen Camaro SS LS LT General Discussions | 5 | 11-14-2010 06:48 AM |
Silver stays top color for vehicles; red, orange rise | KILLER74Z28 | General Automotive + Other Cars Discussion | 12 | 11-13-2009 07:27 PM |
Hard top--> top hard top convert | YaKKO21 | 5th Gen Camaro SS LS LT General Discussions | 12 | 04-13-2009 05:57 PM |
