08-09-2018, 04:50 PM | #99 |
DEVLMAN
Drives: White 2018 ZL1 Join Date: Dec 2017
At the dealership as we speak. Was dropping my car off to have the alignment looked at. Service advisor told me "it should do that with the amount of torque you have". I explained that I'm not the first person to have the issue, blah blah blah. I'll report the findings when this is over with.
Edit: a guy just drove off with my car? Not sure why they needed to take the car to do an alignment and an oil change. At least he wasn't gone long(came back as I typed this). |
08-09-2018, 05:07 PM | #100 |
Drives: 2018 ZL1 1998 SS 1992 Typhoon Join Date: Nov 2015
I have no more sway, now running 325/19 r888r on the rear.
08-09-2018, 06:14 PM | #101 |
Drives: Gen V Viper GTS Join Date: Jan 2018
08-09-2018, 07:24 PM | #102 |
Drives: Order List for ZL1 Join Date: Jul 2017
Fully stock ZL1 here, M6 manual, goes side to side if i pull out to pass and have floored it before it is straight, if I floor it with car straight, no issue. I agree with some here that stated the ELSD is probably the culprit. Not sure if there is a fix.
DRGNZ
08-09-2018, 07:36 PM | #103 | |
Drives: '18 Zl1. '18 GT350. Join Date: Dec 2016
Yes, I had a pretty big thread about it. I got the fix for ya. Check the toe first. Buy every BMR rear suspension part offered. About $800 should do ya. Trust me...............just trust me. Your car will handle completely different now. Night and day. I have ZERO sway or floaty feel. Stays planted............almost, almost like my GTR. It feels like it's eating the concrete now. Remember, GM uses that stamped steel. There's a good Utube video describing how it flex, bends, and torques under load. It's complete garbage to save weight. The BMR stuff is straight up hard core gangsta stuff. I can do 150 mph sprints now, on drag radials, on the streets, without hesitation. Just fyi. My toe was off by a smidget outwards. They moved the front side of the rear tire in just a tick cus I kept having that feeling I was going to go into the wall on a hit. It kept dancing on me. They said it was oh so slightly off, but even that much made it feel that way.
There's only 2 people I trust. 1 of them is me, the other's not you. 2018 Zl1. 1199 RWHP/931 TQ.
08-09-2018, 09:53 PM | #104 | |
DRGNZ
08-09-2018, 10:32 PM | #105 | |
https://www.rdpstore.com/c-4093-trailing-arms.aspx You can start with just doing the upper and lower trailing arms. I know it doesn't sound like much, but good lord. Just doing those 2 pieces will help big time. I went with the fully adjustable one's. https://www.rdpstore.com/c-4110-lower-control-arms.aspx I also added the control arms.
08-09-2018, 10:44 PM | #106 |
Drives: Camaro ZL1 2018 Join Date: Aug 2017
I had the problem and I think it was the alignment thats costs two front tires in 4000 miles (thank you GM...), I installed the coilovers with the engine mods, and now woth 100whp plus the car goes straight....so the problem was in the alignment..
08-10-2018, 07:25 AM | #107 | |
DRGNZ
08-10-2018, 07:37 AM | #108 |
Drives: 2018 Red hot A10 ZL1 Join Date: Apr 2017
I'm 100% stock and have this problem too. Happens all the time if I got WOT no matter the speed.
2018 Red hot A10 ZL1 with black center stripe and Nav. Stock for now!
(SOLD) 2017 Red hot 2SS, M6, NPP, MRC, GM ground effects, ACS Composite decklid spoiler, Mishimoto Catch can, Diablosport i2030 with custom tune, Primary cat delete pipes by CA Performance, Roto-Fab CAI |
08-10-2018, 07:41 AM | #109 | |
Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
08-10-2018, 07:42 AM | #110 | |
08-10-2018, 07:47 AM | #111 |
These part replacements will also help control rear wheel hop. The BMR's are much beefier.
On my 2014 Mustang GT I had the entire suspension replaced with a Ford Racing Fully Adjustable one. It was like night and day difference. Everything was so much higher quality than stock.
Current ride
08-10-2018, 09:23 AM | #112 |
This is not an alignment issue. it relates to the transmission, software and differential. it does it every time punching it hard whether straight or in a corner. To me it is very controllable and not a problem, just something you get used to.
