02-10-2013, 09:23 PM | #99 |
Make your peace with God!
Drives: 2011 Camaro SS/RS M6 Convertible Join Date: Dec 2011
My car is at ECS right now getting the fuel system installed and tuned. They're in NJ as well.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ UNDER MAJOR OVERHAUL!! |
02-19-2013, 07:25 PM | #100 |
Drives: G5.R Join Date: Sep 2010
A ny updates on the Returnles setup?
03-23-2013, 11:40 AM | #101 |
Drives: 2011 SS Join Date: Nov 2011
THIS IS GETTIN LIKE THE ******* THREAD.
03-23-2013, 12:12 PM | #102 |
Drives: Four Door Camaro Join Date: Apr 2010
I've got a lot of info but the product is still not ready to go. I want to sell it as much as you want to buy it!
Andy
Squash Performance LLC
2010+ Camaro 800 LPH fuel systems |
03-23-2013, 03:51 PM | #103 | |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
Andy, it's pretty damn impressive that you want to offer a perfect product and will not be happy till its the best it can be. Cudos to you for this! My setup has been flawless for over 2 months now. The Aeromotive regulator must have had some crap in it and i finally flushed it. Your dual pumps are awesome. Im going twin PTE6766 turbos soon....will these dual 400LPH pumps feed 1000 or so rwhp, 93 octane blended with 2.5 gallons of Sunoco 104 is what i run.? Thanks again!!!!
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
03-24-2013, 02:43 PM | #104 | |
Andy
03-24-2013, 03:43 PM | #105 |
Drives: 2009 ZR1 Join Date: May 2010
Andy,
I want a triple. Where is the "stirring the pot" emoticon? |
03-24-2013, 04:00 PM | #106 | |
Andy
05-15-2013, 09:46 PM | #107 |
Hasbin of Stock Bottom HP
bump this up any status update
05-15-2013, 11:46 PM | #108 |
05-16-2013, 06:09 AM | #109 |
It didn't get squashed, not at all
Andy
05-16-2013, 08:12 AM | #110 |
05-16-2013, 09:01 AM | #111 |
I am hoping to get a batch done in June... You'll know about it the second it's available, no doubt about that.
Andy
05-16-2013, 11:09 AM | #112 | |
That's good news Andy. I know there's a bunch around here waiting. BTW, couldn't be happier with my setup Andy. It has been flawless since knocking the crud out of the regulator. Thanks for a great product and thanks for all your help.
