#99 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: GM Vehicles Join Date: Jun 2010
You may want to get in touch with customer service in your home market first. The phone number for the is 39-06-5465-2000. Please let us know if this works for you. Brandon Chevrolet Customer Service
#100 |
![]() Drives: 2010 Camaro SS Join Date: Sep 2012
I noticed the click on my car this past weekend with some spirited mountain driving...2010 2SS manual. Glad I found the video...I was sure it was something to do with the clutch. I will be getting the parts and doing this washer install asap. Thanks for spending some time to do the video to help us out!
#101 |
Billy The Kid
Drives: Cyber Grey 2SS/RS Join Date: Jun 2009
I just ordered the two part numbers listed through my dealer should have them at the beginning of next week
CGM 2SS/RS[SIZE="1"]
Performance: LT Headers/Stainless Works cat-back, 225/233 Cam, 1LE 3.91 gears, Custom Tune, BMR suspension, MGW Shifter, Stainless brake & clutch lines, Ideal G Master Cylinder, 275s on all 4 corners Aesthetics: ZL1 Spoiler, DIY LED marker lights, AACPlasma DRL, Yellow Calipers, painted factory wheels |
#102 | |
Booooosted.
![]() I laugh because I obviously dropped the ball on this post. lol Sweet. Let us know if it's the problem. |
#103 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
Does this affect all early vin's? I don't think I've ever heard this clicking noise on my car. My vin is in the low 20k range and is an LS3.
#104 | |
Booooosted.
It was something like the first 95 thousands cars that did not have them. If you're not clicking I wouldn't really worry about it until you ever start making the noise. I did not do the left side of the car because it's not making the noise yet. But I have the washer and bolt. |
#105 | |
Billy The Kid
Would this be the kin of thing that will eventually make noise?
#106 | |
Booooosted.
Mine started making the noise at about 35k miles. But I"m at 80k almost now, and no noise from the left side. |
#107 | |
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
#108 | |
Booooosted.
I've done 3 cars now. All were early vins with the latest in the 50k build range. All had them missing so I just figured they were left off. (Mine in #9067 and the other one was under 20k with the third in the 50k range) But good to know it was just variable numbers without them. ![]() Kind of odd though. They must have run out several times. ![]() |
#109 |
Has there been any 2012 camaro's missing this washer? I have a click or clunk also when changing from drive to reverse and on sudden acceleration. Especially since i changed the gears it seems more. Probably because there is more torque on the axles when i accelerate i get the clunk more so. The washers are cheap but i dont want to get it apart and see that they are already installed and the noise is something else.
#110 | |
Booooosted.
#111 |
![]() Drives: 2010 Lingenfelter Camaro SS. 600 HP Join Date: Sep 2009
I just left Healy Chevrolet in Middletown, NY. I was having that same exact noise coming from my rear right wheel. I've broken a couple of half shafts and the noise sounded the same. Well after about two years of having problems with my 9" rear ( I won't say who made it ) I asked Ted to get me a Lingenfelter rear. So far so good until about a month ago when that clicking appeared. Well Sunday night I spent about two hrs on the site looking for a possible problem, when I found your posts and video. Great job!. I called the dealer on Monday, ordered the washer and nut, ( they only did the one side). Went to my appointment today, and bingo no noise, and no charge. So Thanks again for those great posts. 2010 Black 2SS LS3 M6, Lingenfelter 600 HP package, Lingenfelter rear end 4.11 gears, Dynatech Headers, Flowmaster cat back, hotchkiss track pack, lowered 1", Lingenfelter Custom White Stripes, and some Ted Janetty magic. 549 RWHP 527 RWTQ
#112 | |
Booooosted.
![]() I actually just had the other side begin to make the noise. So I'll have to do the other side now. lol |
