02-18-2018, 09:40 AM | #113 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
the trunnion upgrade I believe is the most responsible for quieting down things..and possibly the newer cam lobe designs having better valve train control...the only thing I hear now is the injectors clickin away....
02-19-2018, 09:25 AM | #114 | |||
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
Well, this weekend I got a 2nd heat cycle on it. Also got my transmission drained and filled back up, so should be ready to rock after another heat cycle!! Started getting garage cleaned back up too. Almost looks like there wasn't a swap being done now. Spoke with my tuner a bit, and we are going to watch the weather and try to do some tuning on it here in 2-3 weeks. Crossing my fingers for some decent weather so I can see what it can do!
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
02-26-2018, 01:00 PM | #115 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
updates?
Bone Stock |
02-26-2018, 08:26 PM | #116 |
Actually spoke with my tuner today. Weather looks like it should be decent this week. If it holds out, we are going to tune it this Saturday the 3rd. I'm pumped! It's been hard to build this and then just let it sit the past couple weeks!
Got my heat cycles in, and no signs of any fluid loss/leaks. May go for a brief cruise if I can just to make sure it seems fine but it should be ready to hit the dyno/street! For now, here is a picture of it all back together and cleaned up.
02-26-2018, 10:03 PM | #117 |
looks nice bro...lookin forward to the results!
02-26-2018, 10:06 PM | #118 |
gadget, you got 3.91s?
Bone Stock |
02-26-2018, 10:20 PM | #119 |
Not yet. I have a feeling she's gonna be begging for them after this! That'll probably be the next mod. Then get to working on suspension/drivetrain upgrades
While I wait the long week for Saturday to roll around, anyone wanna take a guess at numbers?? Here is my baseline run. Put down 385/407 with LT headers, no cats, and the rotofab intake, with the stock tune
02-26-2018, 10:26 PM | #120 |
501RWHP and 438RWTQ
Bone Stock |
02-27-2018, 02:08 AM | #121 |
Drives: 2015 1LE Join Date: Oct 2015
490, 445 (dyno jet SAE)
02-27-2018, 08:19 AM | #122 |
I have no idea exactly how much difference there is between the two, but the only dyno around here is a Mustang, if that makes any difference on your guess.
I'm gonna say 498/434...just so I can't be disappointed if she doesn't quite hit the 500 mark.
02-27-2018, 09:22 AM | #123 |
don't matter either way..you still have the pride in doin ur own work...my goals when/if I jump(LULZ) are dependability first! 2nd is always efficiency....3rd but not last is of course....POWER!!!!...worked into the whole mix is safety!
soooo....you gonna go to c'fest this year my man? l8tr...
02-27-2018, 09:39 AM | #124 | |
Regardless of what it puts down, I will be proud to see it rev out and hopefully not explode on the dyno. Then I'll know all this hard work was worth it! Weather now says sunny and 67 degrees..that's as nice as we usually get this time of year here! Just 4 more days!! As for Cfest...probably not gonna happen. That is a LOOOOOONG haul from here. I have a few friends planning to run Rocky Mountain Race Week this year, and I am considering trying to do that one this summer. We shall see.
02-27-2018, 09:50 AM | #125 |
Drives: 2010 Camaro SS Join Date: Jan 2017
Congrats on the build!!!!
F35 Cam / LOD X-1 Manifold / SLP CAI / LS7 Lifters / 3.91 Gears / Hooker Blackheart Exhaust / TSP Headers / SLP Underdrive Pulley / MGW STS / Trunnions and all that other fun stuff....
02-27-2018, 10:01 AM | #126 |
tks fer da kudos! as I have stated before I like to help(or at least point ya in the right direction) and a prob resolved is enough...
as for #'s..that is a new area on these motors..I have seen so many different results and the variables are astonishing....add to the fact that I believe the mustang dyno's show lower numbers(right?) than another dyno.... but...445/470 mustang....460/465...diff dyno...prob seriously off base and don't be pissed at my #'s...and lookin at your previous dyno run I think your valve springs where shot and she went in float at such a low rpm...that curve just doesn't look right... good luck and no worries...it'll hold together just fine! peace.
