04-11-2013, 05:07 PM | #113 | |
Drives: GM Vehicles Join Date: Jun 2010
Great that you were able to get that noise issue taken care of and it also sounds like your dealership experience was quite satisfactory as well. If there should be any issues or questions you may have in the future, we will be happy to help as much as we can. Here to help. Reggie B. Chevrolet Customer Care
04-15-2013, 08:16 AM | #114 |
Drives: 2010 1LT/RS Victory Red Join Date: Mar 2010
Wow, I've been looking for this explanation for almost 6 months. Thank you guys so much for clearing it up. My 36 month warranty ran out on Jan 26th, any clue if this would still be covered under the power train warranty? You're video makes it look easy enough, but you guys are obviously more experienced than I am with turning a wrench. Funny, I'm not scared of pulling off the whole front end to do a grille swap, but pulling a hub off petrifies me. Thanks!
2010 1LT/RS GCN | Roto-Fab CAI | MRT V2.0 | Defenderworx: Chrome Shifter, Polished Door Kick Plates, Polished Door Sills, Black Side Vent Inserts, Chrome Bow Ties, Chrome Cup Holder Surround| GM: Trunk Mat, Cargo Net, Splash Guards, Wheel Mounted Audio Control, PDIM, 4 Gauge Cluster, Footwell & Cupholder Lighting, Switchblade Silver Interior Trim Kit, Premium Floor Mats| Oracle: Aqua Blue Dome & Trunk LED's, Bright White Plate LED's | RS Chrome Valve Stem Caps | Shined by Adam's & Meguiar's
04-15-2013, 08:39 AM | #115 |
aka Patrick
I'm @ 10,300 miles and I've never noticed the sound from the rear when applying load but I notice the same exact sound from somewhere.. when I turn the front wheels and just start to move forward or reverse... wonder if it is the same issue and I just can't tell where the noise is coming from or if there is something similar on the front as well.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft |
04-15-2013, 02:15 PM | #116 | ||
Booooosted.
Feel free to contact me by PM and I'll give you my number and talk you through it or answer any questions. Quote:
04-16-2013, 11:49 PM | #117 |
Billy The Kid
Drives: Cyber Grey 2SS/RS Join Date: Jun 2009
I am putting in rear end gear this weekend so I will be installing the new nut and thrust washer when i put the axels back in. Also I will let you know for sure whether my car had them or not.
Thanks for the DIY
CGM 2SS/RS[SIZE="1"]
Performance: LT Headers/Stainless Works cat-back, 225/233 Cam, 1LE 3.91 gears, Custom Tune, BMR suspension, MGW Shifter, Stainless brake & clutch lines, Ideal G Master Cylinder, 275s on all 4 corners Aesthetics: ZL1 Spoiler, DIY LED marker lights, AACPlasma DRL, Yellow Calipers, painted factory wheels |
04-17-2013, 02:34 PM | #118 |
Drives: 2011 2SS/RS Camaro Join Date: Feb 2011
That sound in your video is the exact same "click" I hear when I make a right turn into my driveway or a right turn up slight hill. It's definitely coming from the right rear. The car never makes the "click" when I make left turns into any driveways. Could this be the same issue?
2018 ZL1 A10
2011 2SS M6. CAI, ATAK, OBX LTs (JRE tune) Autoclub Dragway Best ET: 12.785 Dec 3, 2011. Autoclub Dragway Best MPH: 112.01 Jan 7, 2012 |
04-17-2013, 03:15 PM | #119 | |
Booooosted.
04-17-2013, 03:26 PM | #120 |
Drives: 2000 camaro 3.8L series II Join Date: Apr 2013
CAR WONT START
hi, my 2000 camaro 3.8l series II, just turn off while driving as if it ran out of gas and wouldn't start back up. i left the car over night and came back the very next day and put gas in it. now 1/2 tank full of gas the car started and drove 3 miles before shutting off again, as if no gas. but would not start back up. i got it towed to my house and it was sitting there for a month or so. i went to start and it started, i let it run for about 10 mins and shut it off and tried to restart and no luck. when i crank it turns on but wont start. whats the problem?
04-17-2013, 04:25 PM | #121 | |
Booooosted.
Start a thread will get you more results. |
04-17-2013, 07:12 PM | #122 |
Not sure if I'm the first 90k.....last 6 of my VIN is 146412
2018 ZL1 A10
04-17-2013, 07:59 PM | #123 |
Booooosted.
Yup. 1st 47 thousand. So it's in the number range.
04-17-2013, 08:02 PM | #124 |
Son of a b!$&/!
Thanks for the write up.
2018 ZL1 A10
04-18-2013, 09:15 PM | #125 |
Your profile says you have a 2011. It's just the first model year that they're left off of from what I've read. I have a vin in the 64k. Mine was built in November of 09. You should be in the clear.
04-19-2013, 01:25 AM | #126 |
Really? Damn, must be a different issue then..
2018 ZL1 A10
