07-06-2016, 09:48 PM | #113 | |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
07-06-2016, 09:51 PM | #114 | |
Drives: Camaro Justice Join Date: Jun 2007
07-06-2016, 10:02 PM | #115 |
HAMMER PILOT
Very light cars require big brakes. The 1LE stopped one foot shorter than the ZL1 but weighs 100s less. I am saying that as the hp goes up so does the size/capability of the brakes, it is not based strictly on the weight of the car.
Sent from my SCH-I545 using Tapatalk
07-06-2016, 10:09 PM | #116 | |
07-06-2016, 10:20 PM | #117 | |
HAMMER PILOT
07-07-2016, 09:17 AM | #118 | |
Drives: 2014 2LS (traded in) 2015 1SS 1LE Join Date: Apr 2015
This is oversimplified of course because there are a ton of other things that go into how fast a car stops but HP isn't one of them.
07-07-2016, 09:20 AM | #119 | |
HAMMER PILOT
07-07-2016, 09:22 AM | #120 |
Let's go fishing!
Drives: a car with 8 cylinders Join Date: Apr 2016
I have another question about brakes. I was told that ceramic brake pads will require more braking pressure... meaning I will have to stay on the brake pedal longer, or mash on it harder to stop at a great amount of speed. Will this eventually lead to warped rotors, since they are not carbon ceramic based?
"When choosing between two evils, I always like to try the one Ive never tried before." Mae West 1892-1980
07-07-2016, 09:38 AM | #121 | |||
The bigger brakes on the ZL1 are driven by price point, weight and performance. The six pot brakes on the ZL1 are not designed to stop the car faster. They are designed to provide more consistent braking in extended use, i.e. driving on a road course. The stopping distance is longer in the ZL1 due to weight, but also due to the limited traction patch of the tires. We could put 747 brakes on a Camaro and the stopping distances would not be all that different. Once your reach the maximum traction of the tires, bigger brakes become irrelevant. Quote:
If you have less braking power due to aa pad change, you will have to push harder on the brake pedal to attempt to stop in the same distance as thee more aggressive pad. Once the pedal is on the flow the point is moot. The rel issue will be the lower heat threshold of the softer pad creating the potential for more pad transfer. |
07-07-2016, 09:43 AM | #122 | |
BTW the rotor size is slightly bigger on Gen 6 but I don't think anyone knows about pad size yet. Its still six piston/four piston Brembros
07-07-2016, 09:46 AM | #123 |
HAMMER PILOT
Exactly, more hp = higher speeds which require more braking. Rotor size bigger, car lighter, got it. Couldn't they save money by using the same brakes as 5th gen if lighter.
07-07-2016, 09:54 AM | #124 | |
HAMMER PILOT
07-07-2016, 09:55 AM | #125 |
No sir, more weight requires bigger brakes to dissipate the heat on a road course. The lap times for a well driven 1LE and a well driven ZL1 will be very close to the same over a large number of laps. The ZL1 will hands down get a few of the fastest laps and then begin to fade. The 1LE will be more consistent, not subject to heat soak, and in a 20 lap race... The ZL1 pushes more with the extra nose weight, the smaller front tires will get greasier than the 1LE, heat soak kicks in and power goes down, call it a drivers race.
07-07-2016, 09:58 AM | #126 |
HAMMER PILOT
Lol, the ZL1 and 1LE have the same front tires and wheels. Why does the Z/28 have better brakes than ZL1 but lighter?
