07-10-2019, 09:55 PM | #1317 |
Drives: 2015 1LE Join Date: Oct 2015
Every car on here that was not set up for serious rpm, the manifold falls short. Its a great drag race piece just like the rest but for street driving it is a waste.
If I built a 7500+ motor I would buy it for sure, but anything under 6500 its eye candy.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
07-10-2019, 10:10 PM | #1318 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
@zz true! the LS1tech guys told me (before i got the AFR heads) that the stock LS3 manifold would restrict the heck out of them Shout out to Darth and Hammer
So long story short, im gonna leave my chevrolet performance lifters in the car now, but with yellaterra ultralites and pac1207x and spin it! Sent from my SM-G975U using Tapatalk
Bone Stock |
07-10-2019, 10:17 PM | #1319 |
once i complete my fuel system, clutch, and wheels, im gonna install the johnson short travels and take it as high as it wants
Bone Stock |
07-11-2019, 12:31 AM | #1320 | |
Drives: Never just fly under the radar Join Date: Jul 2015
Just trying to understand not start drama, seems like the LOD is where it's at!
Old Skool |
07-11-2019, 06:07 AM | #1321 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
I've got a 3" Magnaflow axle back I could sell ya!
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
07-11-2019, 06:44 AM | #1322 |
Im still utilizing a 2 1/2" NPP lol I honestly just love the function of it.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
07-11-2019, 07:19 AM | #1323 |
The Camaro mufflers don't do much when you've got headers and no cats open or closed lol but there is zero drone
2010 2SS/RS
07-11-2019, 08:35 AM | #1324 |
Drives: 2010 Camaro SS Join Date: Jan 2017
That's my bad. The car had the truck muffler when I got it. I cut the cats out and added 2.5 inch adapter pipes. Not a good idea at all. And yes. The LOD is definitely where it's at!
F35 Cam / LOD X-1 Manifold / SLP CAI / LS7 Lifters / 3.91 Gears / Hooker Blackheart Exhaust / TSP Headers / SLP Underdrive Pulley / MGW STS / Trunnions and all that other fun stuff....
07-11-2019, 10:56 AM | #1325 |
Drives: Camaro Join Date: Oct 2018
I bought my car used as well and for some reason where the cats were supposed to be they replaced it with smaller pipe than the rest of the 3 exhaust. I cut them out and welded in new 3 pipes. No idea if it provided any benefit
07-11-2019, 10:56 AM | #1326 | |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
Mine feels like it runs out of steam around 6600..guessing that is where my manifold restriction is starting to show itself.
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
07-12-2019, 08:39 AM | #1327 |
Drives: 13' 1LE Join Date: Apr 2012
Stock manifold is just a dive from 6600...
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
07-12-2019, 12:18 PM | #1328 |
Yes sir, my stock manifold on my dyno sheet with the cam and stall BEFORE the LOD started running out of umph around there as well. Now with the LOD, you get above 6000 and man this thing just wants to SCREAM all the way out the back door !!! Non stop except the rev limiter at 7200...
07-12-2019, 01:21 PM | #1329 |
So what's the word on another group buy?? Asking for a friend! Lol
2010 2SS/RS
07-12-2019, 05:03 PM | #1330 |
Drives: 2013 Camaro SS Join Date: Apr 2017
Man i am wanting to see how much of an improvement mine would make with the LOD. You can see on mine where the GPI rod modded and ported intake flatens out.
This is the 3 dynos I did with added mods each time. 2013 Camaro SS M6 Stock trans, clutch, rear gears Blue line: 418rwhp 412rwtq on 93 Octane BBK 1 5/8 Long tube headers and high flow cats Corsa Xtreme ZL1 Exhaust Cold Air Inductions CAI Janetty Remote Tune Red Line: 487rwhp 442rwtq on 93 Octane TSP 1 7/8 Long tube headers and no cats Corsa Xtreme ZL1 Exhaust Cold Air Inductions CAI TSP stage 3 231/246 cam TSP trunion upgrade Custom tune Green Line: 512rwhp 462rwtq on E-85 TSP 1 7/8 Long tube headers and HIGH FLOW CATS ADDED Corsa Xtreme ZL1 Exhaust Cold Air Inductions CAI TSP stage 3 231/246 cam TSP trunion upgrade GPI rod modded and ported intake manifold, heat shield added VMAX PTB Trickflow Gen X 255 heads milled 0.025 and valve job ZL1 fuel pump and flex sensor 850 injectors and on E-85 Custom tune
2013 SS M6, TSP Stage 3 231/246 cam kit, TSP Trunion upgrade, Cold Air Inductions CAI, VMAX PTB, TSP 1 7/8 Long tube headers and high flow cats, Corsa Xtreme ZL1 Catback exhaust, Elite E2-X Catch can, Trick Flow Gen-X 255 heads milled 0.025 and valve job, GPI rod mod and ported intake, ID850 injectors,ZL1 fuel pump, Flex sensor and E-85, Mantic 9000 and 1LE 3.91 diff 512rwhp/462rwtq
