08-02-2018, 05:37 PM | #1 |
Drives: 1980 Pontiac Firebird Join Date: Aug 2014
Anyone running the Bosch 210lb 2200cc injectors in a ZL1?
So first, I'm mostly a lurker on the forums. Have bought some parts on here in the past. I'm building a forged rod/piston LS3 with a LSA supercharger for a '99 Trans Am WS6. BTR stage IV PDS cam. CTS-V front accessory drive with 8.6 lower and 2.55 upper, probably going to go bigger on lower.
I'm at the fuel system now. Going to be E85, -8 feed/return, dual 450s with 2nd pump on hobbs switch. I need injectors now. I've thought about the id1050x, FID1300 (can get a good deal on these). I keep reading about the Bosch 210s. Alot of turbo LS guys run them, about $500 a set. Most say they use id2000 data for them and run fine, and that they are basically the id2000 except not in a close matched set. When I search bosch 210 ZL1 it shows several sellers offering them. Just wanted to see if anyone out there is running them first. |
08-02-2018, 06:57 PM | #2 | |
Boosted Moderator
The idle quality is very good, but I say that with the caveat that we idle my car at close to 900 rpm.... She makes 2000 + RWHP, and I can still drive her around the neighborhood with no issues, (manual transmission). We shift the car at 9,000 rpm.... https://www.siemensdekafuelinjectors...ev1-connector/
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
