01-22-2018, 03:03 PM | #1 |
Drives: 2017 Camaro ZL1 Join Date: Nov 2016
Camshaft ideas
I've been searching for a new camshaft. There are several out there specifically for the ZL1, but I can't find one with an aggressive idle anywhere. Any suggestions?
01-22-2018, 03:51 PM | #2 | |
Drives: 2019 ZL1-1LE A10 Join Date: Jan 2017
This is with the stock NPP muffler. It is very loud, especially under WOT. I can only imagine with a Corsa or Borla muffler....
19 ZL1-1LE A10
01-22-2018, 03:59 PM | #3 |
01-22-2018, 04:06 PM | #4 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
Brian tooley racing has some grinds for the ZL1. Cam selection and characteristics should be matched to your transmission type, A10 or Manual, and build goals.
01-22-2018, 04:14 PM | #5 |
Are you going to try the install yourself? This 6th Gen is a bear to do a cam install. All of my Mods were done by 21st Century Muscle Cars in Dallas. Most of the shops have a "custom grind", which is a little misleading. There are really only a couple of cam manufacturers that make them for everyone to private label. The specs on mine are 227/244 .633/.631 115 LSA +5. I can't remember is it was ground by Brian Tooley or Comp Cams. I am at 706 RWHP now.
19 ZL1-1LE A10
01-22-2018, 04:26 PM | #6 |
Dyno Show Queen LOL
Drives: 16 SS & 17 ZL1 Both Yellow Join Date: Jan 2014
After 4 modded cars the aggressive cam phase is gone.. I just think this is such a nice car its hard to tear it up like that.. I use the term tear it up loosely.. I'm doing a cam with a fuel lobe and similar to stock profile..
I have had 2 BTR cams in LS engines Stage 3 and stage 4 and lingenfelter cam in the other, and one LGMotorsports back in a LT4 in the 90s.. all were fantastic.. I can't see going wrong with BTR, Pat G, TSP, or even Vengence Racing or who ever bought the night fury or designed the night fury that MO FO new what he was doing.
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber |
01-22-2018, 04:38 PM | #7 |
Drives: Fast Join Date: Mar 2015
Brian Tooley, Pat G, Texas Speed, Vengeance, RPM, and hundreds more all have solid choices for the LT4...
Go with something middle of the road is my advice. Don't go too small or the gains won't be there, and don't go too aggressive after sound because it will drive like crap around town. I personally have ridden in a car with the Vengeance Stage III cam and it sounded amazing at idle and screamed up top. The car put down like 775 RWHP and over 800 RWTQ with a crazy curve. There's videos of it on their youtube channel just search Vengeance Stage III LT4. |
01-22-2018, 07:58 PM | #8 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Just remember that an aggressive idle cam can not be the only criteria. Nothing is more aggravating than a poorly matched cam swap. Make sure you have appropriate mods to work in concert with your cam. A nasty idle/sound do not mean a good running engine.
2018 Camaro ZL1 1LE NFG; ARH 2” headers, catless mids, ARH full exhaust, Lingenfelter 18% lower pulley, ATI Harmonic Balancer, Roto-fab CAI, EE-catch can, TM ported TB, NX Lid, BMR strut tower brace. Aeroforce dual pod interceptor gauges. Tuned by Vengeance Racing!!! 644 HP @ 6250 rpm / 689 trq @ 3660 rpm
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
01-22-2018, 09:32 PM | #9 |
1959 Chevy Apache 4X4
Drives: 2017 ZL1 Join Date: Feb 2016
17ZL1
did you have them install their performance package? Or did you just do a cam? both?
2017 ZL1 garnet red/A10/nav/pdr/sunroof/CF hood insert
1100 2-1-17 2000 2-14-17 3000 2-15-17 3000 TPW 3-13-17 3300 3-6-17 3800 3-13-17 4B00 3-13-17 4200 3-15-17 4800 3-22-17 5000 3-27-17 6000 3-28-17 |
01-23-2018, 12:45 AM | #10 |
Drives: none Join Date: Nov 2012
Aggressive idle in a cam is usually the result of a lot of overlap....not something you really want in a blower car. Most big blower cams are barely touching the bottom end of small NA cams.
01-23-2018, 07:51 AM | #11 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
Looks pretty aggressive for a blower cam. My NA cam has lower duration and overlap and similar lift, but I thought it would not be appropriate for going FI in the future.
________________________________________________
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ |
01-23-2018, 08:36 AM | #12 | |
I did cam w/ 32% lobe, BTR dual valve springs, LS7 lifter/tray, pushrods, Tony Mamo TB, ported Supercharger, Rotofab CAI, ARH headers, X-pipe, NKG plugs, ATI dampner with LPE lower pulley and a few other things. Matt really knows his stuff and is a great tuner.
19 ZL1-1LE A10
01-23-2018, 08:58 AM | #13 | |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
01-23-2018, 09:20 AM | #14 |
No upper pulley, just lower. No heat issues. I haven't been to track yet, but have a track day set up for March (road course). I've never been into drag racing, but may get a set of rear tires just to try it. I've always preferred road course, more bang for the buck. Six, 15 minute sessions vs a couple 11 second runs. but regardless, I'm anxious for the weather to warm and see what the car is capable of doing. I suspect I'll have to re-learn how to exit the corners with so much low end torque and possibility of spinning the tires.
19 ZL1-1LE A10
Tags |
cam, camshaft |
Thread Tools | |
