08-29-2018, 04:15 PM | #1 |
Drives: blue rs Join Date: Aug 2018
Torque converter/transmission shutter
I have a 2012 rs v6 with 13000 miles and am getting some shuttering when the tranny is up shifting. It is not constant but the longer you drive it the more is does it. I was wondering if it is electrical or is the torque converter. It doesn't throw any codes.
08-29-2018, 05:56 PM | #2 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Have you ever had the transmission fluid changed?
