06-04-2014, 05:09 PM | #1 |
Drives: 2014 chevy camaro 2lt RS Join Date: Nov 2013
washing my baby
2 questions , what is a good item to use to filter the water , if all you have access too is well water and what is a good item to use to keep the windows clean because i seem to have these little sticky patches than when i try to clean them they streak and are hard to get off the window , thank you
GMG1(SW) usn ret Battleship sailor
06-04-2014, 05:18 PM | #2 | |
Drives: 2013 2LS BLK Join Date: Oct 2013
And more than likely it would be much cheaper to use detail spray while you are drying instead of investing in a water filter.
06-09-2014, 10:15 AM | #3 | |
Drives: 2010 Mazdaspeed 3 Join Date: Mar 2012
One would be to use something like our clear water systems, which filter sediments from the water, while providing a water-softening effect. This wont eliminate water spots completely, but it will remove the harmful the particles that create damage. The other option - The CR Spotless System - uses water deionization to effectively remove anything that can cause water spots. |
