07-19-2014, 05:03 PM | #1 |
Rider of the short BUS
Drives: Ukon/F350(work)/Intruder800 Join Date: Dec 2008
Wheel & Tire Size
Guys
I have a 2013 Camaro V6. I currently have the factor 20" wheels and tires. Is it possible to install 20 x 9.5 on the front and 20 x 11 on the rear. I was looking at the forgestar F14 in either matt black or gunmetal.
SIM with CGM rallies
07-19-2014, 06:10 PM | #2 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Yes to both but make sure you check the offsets first. That can make or break the deal for fitment and for appearance.
