03-05-2018, 01:00 PM | #1 |
Boost drop
Ok so I'm hitting 21lbs at 4500rpm but it drops to 19lbs towards redline. What can I do to keep it steady at 21lbs?
Running twin 62/60 84ar turbos with twin turbosmart 45mm hypergates. Gates and turbos are hood dumped. Using the G Force II boost controller.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
03-05-2018, 01:44 PM | #2 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
stronger wastegate springs? that's all i can think of unless you've got a boost leak somewhere else.
where are you getting your signal for the controller?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
03-05-2018, 02:45 PM | #3 |
Drives: '10 Camaro 2SS Join Date: Jul 2013
I’m not sure if the gforce 2 has the feature but the Eboost2 can compensate for boost drop off and keep it steady. This a very common problem and happens on all engine sizes and types. Especially when the turbos are too small on the turbine side.
03-05-2018, 03:17 PM | #4 |
Drives: 2011 Camaro 2SS Join Date: Sep 2015
Could be it's spiking to 21 psi and leveling back out to 19 psi
03-06-2018, 11:18 PM | #5 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
you can have issues trying to run double wastegate spring pressures with an ebc. what's your base spring pressure?
03-07-2018, 03:34 PM | #6 | |
Drives: it changes Join Date: Nov 2010
http://gfb.com.au/products/boost-con...troller-detail Is it installed and configured correctly to make use of this ? And as others have said....do you have a graph of boost vs rpm ? in that is the 21psi momentary or does it hold it for a while before dropping ? Can you see what changes in duty the controller is applying to the solenoid to try and maintain boost, if any at all ? 2psi is a small drop and should be easily corrected unless there are some mechanical limitations |
03-08-2018, 02:14 PM | #7 |
After I messed with the tune a little it seems to of been corrected. The car was super fat. Pulled 8% fuel out and it don't spike 21lbs and drop off. It comes in smoother and peaks at like 22 now.
03-10-2018, 11:02 AM | #8 | ||
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
03-10-2018, 11:52 AM | #9 |
Drives: 2019 ZL1 1LE A10 Join Date: Jan 2015
That’s actually kinda expected...
Ryker #29
2019 ZL1 1LE A10 2015 Z/28 #809 |
