12-06-2018, 10:35 AM | #1 |
Header coating?
I am about to install the ARH long system on my ZL1 and I have seen conflicting reports about heat and the starter... What is your opinion about coating these headers? This car is a weekend driver in the warmer months with 4-5 trips to the drag strip. Just wondering what every one thinks about this.
12-06-2018, 10:46 AM | #2 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
I'm in south Texas. Heat is a killer here. I just ordered a set of Kooks headers and they are getting ceramic coated.
It's my opinion that this is a good idea and will help with temps under the hood. I even thought about header wrapping instead of the coating as I have seen with other cars that this helps more with temps. I didnt go that route due to conflicting opinions concerning wraps being a problem with headers or that they soak up oil and possible fires could happen. I went coated to play it safe. |
12-06-2018, 11:09 AM | #3 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
Coating works for sure. Do it if you got the money.
12-06-2018, 11:43 AM | #4 | |
12-06-2018, 11:45 AM | #5 |
12-06-2018, 01:36 PM | #6 |
Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
What size did you go with? 1-7/8's or the 2in? I have the 1-7/8's and had mine coated and having no issues with the starter here in Fla.
Former Ride: 17 Camaro 2SS, M6 - Fifty | Procharger P1SC | 3.7 Pulley | Stage 2 IC | Race Bypass | DSX FF Kit | JRE Custom E85 Flex Fuel Tune | LT4 Fuel System | JMS Voltage Booster | MSD Plug Wires | American Racing 1-7/8's LT Headers Full System Catback | Baro Breakout Harness | LT4 Map Sensor | Katech Ported TB | MMS Oil Catch Can | 160 Thermo | Solo Performance J-Pipes
12-06-2018, 01:41 PM | #7 |
I went with the 2 inch ones... not sure what future mods will be so i went overkill on them! I did find a local guy that will ceramic coat them for $300. Since its not a bunch of money I am gonna go ahead and get them done!
12-06-2018, 01:43 PM | #8 |
yeah not a bad idea. The 2in may be just a slight bit closer possibly to things
12-06-2018, 01:48 PM | #9 |
12-06-2018, 05:26 PM | #10 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Coating has no down side. Great idea!
2018 Camaro ZL1 1LE NFG; ARH 2” headers, catless mids, ARH full exhaust, Lingenfelter 18% lower pulley, ATI Harmonic Balancer, Roto-fab CAI, EE-catch can, TM ported TB, NX Lid, BMR strut tower brace. Aeroforce dual pod interceptor gauges. Tuned by Vengeance Racing!!! 644 HP @ 6250 rpm / 689 trq @ 3660 rpm
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
12-06-2018, 07:33 PM | #11 |
Drives: 2018 NFG ZL1-1LE Join Date: Jun 2018
Coat all of it. I have race deck flooring in my garage. The floor tends to buckle up a bit under the car from the heat of the cats when I first pull it in. I have a fan that blows air under the car and prevents it. After coating the entire system, I noticed less movement of the floor if I didn’t use the fan. Besides it looking really cool it, will help keep the heat in check quite a bit.
12-07-2018, 05:36 PM | #12 | |
12-07-2018, 06:00 PM | #13 |
Drives: 6th gen Join Date: Aug 2013
Drool
‘22 2SS 1LE M6 Summit White - RF, Flexfuel, LT2 intake, 95mm tb, ATI udp, VT ramair, full 28” dragpack - 11.68@122
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) |
