06-05-2013, 05:16 PM | #1 |
Drives: 2010 2ss red LS3 Join Date: Aug 2011
Help!
I put on 1LE tire & wheel package on my Pedderized 2010 SS,now E-brake cables rubbing on inside the wheel corners.Any suggestions?
06-05-2013, 05:27 PM | #2 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
zip ties...18 inch thickness contractor type
06-05-2013, 05:29 PM | #3 |
Drives: '02 Trailblazer, '12 Camaro 2SS/RS Join Date: Jun 2012
common problem - do a search, there is a thread or two about how to deal with it.
06-05-2013, 05:59 PM | #4 |
Drives: BLACK 2SS/RS Join Date: Sep 2009
CCW polished 505a's
Front 20x10 w/275/40/20's Rear 20x11.5 w/305/35/20's Eibach 1" Pro Spring Kit Factory GFX MPD1 spoiler painted bowties 15% tint |
06-05-2013, 06:55 PM | #5 |
Anyone know how GM dealt with it on the 1LE?Also my car is very low,650mm measured Pedders style.
06-05-2013, 07:12 PM | #6 |
As mentioned this is a very common issue with wider wheels. Don't loose sleep over it. Just zip tie it or use the rubber hose/clamp method. I chose the clamp method and I'm lowered 1".... Several others I know are lowered 1.5"+ with 11.5" wheels and they have also used the hose and clamp method with no problems. I have been running since 2009 this way.
CCW polished 505a's
Front 20x10 w/275/40/20's Rear 20x11.5 w/305/35/20's Eibach 1" Pro Spring Kit Factory GFX MPD1 spoiler painted bowties 15% tint Last edited by FEN; 06-11-2013 at 08:41 PM. |
06-05-2013, 07:56 PM | #7 |
FEN I think you are right,its not rocket science.Hose, hose clamp & done.Thanks Guys!
06-06-2013, 02:57 PM | #8 |
Drives: Camaro SS Join Date: Mar 2011
Tie back the cables with a zip tie. Some cars need it some cars dont.
