05-01-2020, 03:04 AM | #1 |
weSS1LEy
Drives: 2015 camaro 2ss/rs/1le Join Date: Sep 2015
Raising compression vs supercharging
Hypothetically if I wanted to do milled heads and increase compression, would that make it more difficult to supercharge later on?
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
05-01-2020, 05:24 AM | #2 |
Drives: 2014 2SS/RS/1LE Join Date: Mar 2015
Not necessarily. It will limit the psi you can run on the supercharger though.
05-01-2020, 06:39 AM | #3 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
It makes it less efficient to supercharge yes. You can still do it but you limit yourself.
05-01-2020, 07:30 AM | #4 | |
Started#gottalovethatblue
05-01-2020, 11:18 AM | #5 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
You could always boost with this, lol
05-01-2020, 11:49 AM | #6 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
05-02-2020, 10:15 AM | #7 | |
Drives: 2010 SS L99 Join Date: Sep 2018
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
05-02-2020, 02:01 PM | #8 |
Banned
Drives: 2015 Camaro Join Date: Aug 2018
What about these?
05-02-2020, 02:09 PM | #9 |
'It's an experiment'
I did — milled heads, cam, and LSA SC On my L99...
-Don
747 RWHP 794 RWTQ
05-02-2020, 10:49 PM | #10 |
weSS1LEy
So say a local shop installs Maggies at 8 pounds of boost (a safe low number) would a compression ratio of 11 or 11.5 : 1 inhibit this? I’m totally guessing at what a CR might be.
Also aren’t the lt1s 11.5:1?
05-02-2020, 11:01 PM | #11 |
Banned
Yes, LT1's are 11.5:1, but the LT4 is 10:1 running 9 lbs of boost.
05-02-2020, 11:17 PM | #12 |
Drives: 14 SS/ 1LE Join Date: Jun 2013
LT1s are direct injected. Different ballgame
2014 1SS/1LE
AGP 57/57s, E85 + meth injection, Monster triple, ZL1 diff swap, Z28 coilovers |
05-03-2020, 01:52 AM | #13 |
weSS1LEy
Ahh ok interesting. Maybe it’s it’s not worth bumping the compression. Kinda want to have my cake and eat it too.
05-03-2020, 08:32 AM | #14 |
old school chevy rodder
Bumping the compression would just make it hard to raise boost levels below low and also maybe make you have PTV interference if not some different angle aftermarket heads like say GPI's ls7 style, you have a lot of duration but not so much lift with a wider LSA for good torque, you are about my specs for my daily driver cam I use until build some day.
Also BTW just increasing compression will not gain you that much more HP with what little you could glean from shaving the heads you may gain just 5 hp......… Myself I am hoping to go GPI a couple years down the road as I have a gorilla on my back with daughter graduation in Neuro science in June..... And I will alter for my being stroked the Cam specs as more volume allows to make more gas in thus more power...we are giant air pumps...… And when you do go boosted you will want to ditch that cam like me.... The nice things is five grand for a cam and small bore heads is noting compared to what you could ditch on a blower/turbo..and then you would wish your forged.... Good Luck!
