Old 05-04-2014, 07:01 PM   #1
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
VVT Q and A
Figured I'd start a thread to help field and answer some questions about our vvt cams, or vvt grinds in general.
I welcome any member that may have a cam of ours, or any vvt to post their experience so others can have a good thread to pull up on the search function.
We offer 4 common vvt grinds, but we move the specs around to accommodate goals and usage for each combination.
What I can tell you that you will see with VVT vs conventional grinds, is earlier tq than most ls3 cams, and the power will carry longer. Tq curve will be flatter.
As always with ANY cam, proper converter selection is a must, as well as supporting mods to compliment the setup.
If you guys/gals have any questions ask away!
Rhino79 is offline   Reply With Quote
Old 05-04-2014, 08:38 PM   #2
sasquash1984
502 RWHP N/A
sasquash1984's Avatar
Drives: The yeti
My 2 cents I have the ss4 vvt cam with full bolt ons and head work u need a 4000 plus converter to take the most advantage out of your 60 ft and et at the track. I noticed a huge difference going from the ls3 conversion and 3000 stall to vvt stage 4 cam and 4000 single disc almost dropped 3 1/2 tenths on a bad air night. Power is there and drivability is good still
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
sasquash1984 is offline   Reply With Quote
Old 05-04-2014, 08:57 PM   #3
Pima
Pima's Avatar
Drives: 2013 2ss/rs/1le vr.
i am also looking for that 500rwhp. i am currently at 475rwhp with comp cam, 2" stainless works headers with no resonators or cats+npp exhaust, CAI and vmax throttle body with a tune from cincy speed. i know i need to get the heads done but i am lost on what to get or where to start?
Pima is offline   Reply With Quote
Old 05-04-2014, 09:29 PM   #4
matt55
matt55's Avatar
Drives: CTS-V
Do you have a dyno of a VVT cam with the cam timing static vs advance/retard to show the advantage of shifting timing around ?
10.8@130.8 610 whp, CAI, 2.5, E85, id850 on street tires.
matt55 is offline   Reply With Quote
Old 05-04-2014, 10:16 PM   #5
Rhino79
Rhino79's Avatar
Matt55 I have on the old dyno PC at work. Most all our cams I have a starting point for now.
At full advance or fixed 0 usually you see power drop off past 5000-5200 rpms.
Old 05-04-2014, 10:19 PM   #6
Rhino79
Rhino79's Avatar
Exactly. The heads shift the curve up a little.
Max gearing and at least 4000 are ideal for that cam.
It's a max effort na cam but still drives nice.
Old 05-04-2014, 10:23 PM   #7
trw427ss
trw427ss's Avatar
Drives: 2013 2SS/RS L99
Hey man I think I need some help! What's a VVT cam? LOL
2013 2SS/RS L99/A6 Crystal Red Metallic Tincoat 12.76@108.98mph Bone Stock
12.46@111.19mph with New Era CAI & U/D Pulley
12.12 @ 114.16 after Stainless Power headers and no tune yet on stock P-Zero's!
12.007@ 115.20 With 18" Drag Radials - 11.93 @115.19 Added a PTB 11.76 @116.59 With Yank SS3200 Converter - 11.63 @116.52 After PI and Tuning 11.44 @118.75 New Best
10.72 @127.93 after heads and Cam and Yank SS3600
trw427ss is offline   Reply With Quote
Old 05-04-2014, 11:25 PM   #8
sasquash1984
502 RWHP N/A
Drives: The yeti
FYI vvt comes with the autos, for ls3 m6 I believe fly cutting the pistons first
Old 05-05-2014, 12:02 AM   #9
62nalide
62nalide's Avatar
Drives: 2013 SS
I'll share my results May 15 or 16th once I run the SS4 with a 3600 circle-D triple disk, track times will follow as well.
62nalide is offline   Reply With Quote
Old 05-05-2014, 12:05 AM   #10
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
June-July I'll share my experience with it as well.
Nightmare2012 is offline   Reply With Quote
Old 05-05-2014, 07:01 AM   #11
Rhino79
Rhino79's Avatar
Old 05-05-2014, 07:32 AM   #12
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
ss3 with a vortech on the car I just sold...654 at the wheels and ran 8.71 in 1kft which is mid 10s at the track for a quarter mile. Solid running car, sounded awesome. Drove good. Has a new owner now up in KC, KS.
Ryan spec'd the LSA different for blower cams that are of the ss3 variety...also helps matching the stall up...I had a circleD that flashed 4k on a launch. 3600 was the rating. More hp pushed that stall up a bit. it cut the best of a 1.49 60 on MT DR's...dead consistent 1.50s.
-John S.
Old 05-05-2014, 08:38 AM   #13
matt55
matt55's Avatar
Drives: CTS-V
I just think I would be a good selling point for all the people on the fence vs "ls3" conversion.
Old 05-05-2014, 11:00 AM   #14
Rhino79
Rhino79's Avatar
Next one I do, I will do a popular setup fixed like a 112+4. So I will fix it at 108 icl, then overlay the final graph over it.
