07-21-2021, 09:03 AM | #1 |
Drives: 15 Camaro SS Join Date: Oct 2018
Need a little help
Hey guys. So it seems when I'm into the throttle my traction control is activating even though I'm turning off the nannies. Ted Jannetty is tuning the car remotely. I just brought this to his attention so I'm waiting for his response. I hold the button down for roughly 10 sec and both lights illuminate on the dash. A good bit of the time the traction control is still activating. Now I have after market wheels and do not have tpms sesnors in them. When I start the car, the warning light for them comes on. Sometimes its flashing. Could this be causing the traction control to not disable and if so, is there a way around this short of having sensors installed? Thanks for any help. I'm tuning with Hp tuners
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
07-21-2021, 09:44 AM | #2 |
Drives: 11 2ss 02 ws6 Join Date: Jul 2021
No thats not it I have z28 wheels on my car and my tmps sensors are bad they are always on. And I can turn my traction control off and it stays off. Pull the fuse for it the. It won't come on
07-21-2021, 10:05 AM | #3 |
Then I must have an issue. My data logs are showing traction control is turning on even though I have both dash lights on showing its disabled. It is for sure going off though. I jump on it, car immediately pulls timing, slows down and up shifts any time traction starts to give
07-21-2021, 11:39 AM | #4 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Traction control will still activate if wheel hop is occurring. I have the same issue, but if I'm getting wheel hop I need to get out of the throttle anyway. I notice it kicks in more from a stop. There is a way to shut it down completely in the tune there is a thread in the forums about it somewhere. You can also pull the ABS fuse that will kill it all but your abs stabiltrac all those lights will come on. I don't believe it will go into limp mode though, but I haven't tried it.
If you aren't getting wheel hop then I am not sure. May have to be addressed in the tune, I'm sure Ted can get it sorted.
07-21-2021, 02:43 PM | #5 | |
07-21-2021, 04:55 PM | #6 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
It's automatically coming on to keep you from going full Mustang and throwing that puppy in the ditch!
It knows! |
07-21-2021, 05:00 PM | #7 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Lol!
You can pull fuses 40/43 -or- Ted can defeat it in the tune. |
07-21-2021, 06:54 PM | #8 |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
Your TPMS sensors have absolutely NOTHING to do with your traction control. So get that out of your head right now.
07-21-2021, 06:58 PM | #9 |
Some of your traction control is in the restraint control module, as it has the yaw, pitch and roll sensor in it. HP tuners cannot access that module. Variations in wheel diameter, if not calibrated from stock values, can trigger ABS and traction control events as well.
07-21-2021, 07:00 PM | #10 |
Lol!!
07-21-2021, 08:53 PM | #11 |
Jannetty has stated otherwise. Im going to have to have sensors installed
07-21-2021, 09:08 PM | #12 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
There is definitely a section of the tune where you can make TC changes. But you hold the button down 10 seconds. Does it do it if you hit the button twice quickly? It gives you the same competitive mode just easier to do. Just a hunch I have. You got the suspension mods to avoid wheel hop so I doubt it's that.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
07-21-2021, 09:22 PM | #13 |
2&THEHIT
True- holding the button defeats stabilitrac, but not traction control. Two different items.
07-22-2021, 06:52 AM | #14 | |
