06-13-2017, 12:16 PM | #1 |
FIC 850cc injectors
Selling my FIC 850cc injectors out of my 2013 ZL1. Injectors were in less than a year, upgraded to larger injectors for a new setup. Injectors are in good condition selling $300 shipped.
Rotofab CAI, 2.55 upper, 8.6 lower, heat exchanger, ID850 injectors, boost a pump, custom ground comp cam, kooks long tube headers with high flow cats, E85 conversion flex fuel, nkg plugs, NT05R Drag radials, 712 rwhp built by Lethal Performance. Instagram Gonz_ZL1 Last edited by DerrickG; 06-21-2017 at 05:02 PM. |
06-13-2017, 01:09 PM | #2 |
Drives: 2011 2SS Synergy Green Join Date: Nov 2011
Edit: Nevermind.
L99 With a Maggie
06-13-2017, 06:11 PM | #3 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Will these work well in a E85 set up in a LS3??
Orange Krush II
06-13-2017, 07:05 PM | #4 |
I was running them straight E85. They worked great for my set-up. I was at 712 rwhp on straight E85 and they still had plenty room left. They max out just shy of 800rwhp
Rotofab CAI, 2.55 upper, 8.6 lower, heat exchanger, ID850 injectors, boost a pump, custom ground comp cam, kooks long tube headers with high flow cats, E85 conversion flex fuel, nkg plugs, NT05R Drag radials, 712 rwhp built by Lethal Performance. Instagram Gonz_ZL1 Last edited by DerrickG; 06-13-2017 at 07:18 PM. |
06-17-2017, 04:58 PM | #5 |
These are still available
Rotofab CAI, 2.55 upper, 8.6 lower, heat exchanger, ID850 injectors, boost a pump, custom ground comp cam, kooks long tube headers with high flow cats, E85 conversion flex fuel, nkg plugs, NT05R Drag radials, 712 rwhp built by Lethal Performance. Instagram Gonz_ZL1 |
06-21-2017, 05:02 PM | #6 |
Price drop to 300+ shipping
