Old 06-29-2017, 08:29 AM   #1
Royal Tiger
Drives: 2013 2SS/RS Convertible
Ceramic coated headers yay or nay?
I was dead set on Kooks ceramic coated long tubes, but the shop I just had install my 3.91 uses non-coated American Racing headers. I asked about the coating and I was told the high quality stainless headers do not need it. I thought the coating helped with the heat as well as for corrosion protection?
Royal Tiger is offline   Reply With Quote
Old 06-29-2017, 08:39 AM   #2
Bo White
Bo White's Avatar
Yes coat them if you can afford it.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 06-29-2017, 08:44 AM   #3
BLU DUCE
BLU DUCE's Avatar
Spike III Build 2011 IBM 1SS/RS [COTW 6/25/12]
Plus one all the way.
Old 06-29-2017, 08:50 AM   #4
xc_SS/RS
Drives: 2010 Camaro SS/RS
Times infinity. Definitely recommend it plus black headers look awesome
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 06-29-2017, 09:41 AM   #5
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Well, since we're already at times infinity, I'll just say "f*#k yea, get it done".
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 06-29-2017, 11:16 AM   #6
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Yes to the infinite power get them coated! www.marylandspeed.com offers free ceramic coating for Kooks headers with the code 'FREECOATKOOKS' or at least they used to. It is a high quality coating that has a lifetime warranty just like their headers.
Just as an example for reason why you should, my buddy got Stainless Works headers with ceramic coating and did a temperature comparison between stock manifolds and the ceramic coated headers. The stock manifolds after 30 minutes of driving were 500*F while the ceramic coated long tubes after the same 30 minutes were 400*F. 100*F is a heck of an under hood temperature drop.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 06-29-2017, 11:37 AM   #7
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
Ceramic coating will help keep the heat down, do it!
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 06-29-2017, 03:45 PM   #8
Avenging Orange
Avenging Orange's Avatar
No need unless you want to brag about it. It's gonna get hot under the hood regardless.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 06-29-2017, 06:56 PM   #9
csmith4153
csmith4153's Avatar
Drives: 2011 1SS
non coated headers will look like garbage down the road. Get them coated, my headers still look like the day I put them on 5 years ago.
csmith4153 is offline   Reply With Quote
Old 06-29-2017, 07:34 PM   #10
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
Coat them if nothing else for looks alone the lower temperature thing is a plus too
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
Old 06-29-2017, 08:52 PM   #11
Jrichards73
Jrichards73's Avatar
Drives: 2011 2SS/RS Victory Red
My kooks came black coated even though I ordered them chrome, they just disappear in the engine bay. Any reduction in heat under hood is a win.
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB.
Jrichards73 is offline   Reply With Quote
Old 06-29-2017, 10:16 PM   #12
Olddudesrule
Resident nomad
I never brag about it.......
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
Old 06-30-2017, 05:14 AM   #13
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
Now's the time to do it if your going to do it and they looks so pretty when you get the back. They lose some of their shine a bit, but mine still look great after 4 years compared to if there non-coated.
newagemuscle is offline   Reply With Quote
Old 06-30-2017, 05:15 AM   #14
newagemuscle
Philippians 4:13
That's exactly my thoughts.
