02-14-2019, 06:35 PM | #1 |
Drives: 2012 2LT RS Join Date: Apr 2018
Help: I'm ignorant about suspension
As the title says...I'm ignorant.
I have a 2012 2LT w/ RS package, so big fat 20 inch wheels, staggered. I'm looking to improve: Body roll & handling bumps in the road. I want less roll in corners, and a more planted feel. For the bumps, I feel everything in the road (completely expected) But it is very violent / rougher than another v6 I rode in. The mileage is 71000 miles currently. All suspension is stock. I searched a bunch but found a ton of short hand that I didn't understand. Does anyone have a good writeup? Thanks! |
02-14-2019, 07:56 PM | #2 | |
Drives: Miss Con Ception Join Date: Aug 2016
The RS wheels/tires with their short sidewalls and heavy weight will make the bumps and potholes feel worse. But, they are great for handling! My first step was a Pedder's package that is inserts for the front radius rod and rear cradles bushings. Before that I always felt the rear was sloppy. I had a street performance alignment done after installing those. See the stickys at the top of this sub-forum for those specs. Together I have quicker turn-in and more stability under braking. A stiffer rear sway will reduce roll and transfer more force to the wider back tires to reduce the understeer built in to these cars. If you have a manual in your V6 you have a limited slip differential. That can get you into some trouble when inducing oversteer. Most of the aftermarket sways are adjustable so you can adjust them to fit your driving style. If you feel you have excessive bounce you should check your shocks for any signs of oil. Since you already feel the ride is rough you may want to stick with stock. SS shocks are probably a bit stiffer, 1LE shocks even more, etc...
2011 1SS/RS LS3 CGM
02-14-2019, 08:35 PM | #3 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Also get a set of newer 2012+ ZL1 2013+ SS LCAs and Toe rods and go wider rear bar but you'll need a Brembo set up.
Orange Krush II
02-14-2019, 11:34 PM | #4 | |
02-15-2019, 06:06 AM | #5 | |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
I think those things will get you started in the right direction. |
02-15-2019, 12:12 PM | #6 |
Instagram: Sangstah
Sway bars and springs help a lot more than you think.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
