![]() Drives: 2011 SS Join Date: Apr 2018
20" Giovanni Dakar 5 black
Looking for some feed back on wheel fitment. I have a 2011 ss. Found a set of used Giovanna dalar wheels for sale. 20 x 8.5 fronts and 20 x10 rears ET 35 on all 4. I read on here before that the offset of the fronts need to be ET 20 and the ET 35 for the rears is correct. Stock offset for the front 8" wide is 35. I think the fronts will fit, just be more tucked in than the rears. Just looking for some confirmation before dropping the cash. Thanks.
376 cubic inches of fun
The correct offset depends on the wheel width.
Here's a useful app that will get you the correct offset when you deviate from the original width wheel. It's important to avoid contact with suspension surfaces on the inside tire wall, which can happen with the wrong offset when going to a wider wheel. https://www.1010tires.com/Tools/Wheel-Offset-Calculator The original wheel widths and offsets are here: https://www.camaro5.com/forums/wiki....WHEELS___TIRES |
Thread Tools | |
