Old 10-14-2021, 01:13 PM   #1
Redrockit
Redrockit's Avatar
Drives: 2014 2SS/RS MT
Stabilitrak Competitive Mode Question
According to the posts I've been reading here, it is possible to set Stabilitrak to competitive mode (two short presses) which is a "reduced" mode, and also to completely turn the computer off. On my car, two presses shows competitive mode on the display, AND icons showing that both Stabilitrak and traction control are turned off. In other words, comp mode=everything off. Am I missing something?
Redrockit is offline   Reply With Quote
Old 10-14-2021, 02:16 PM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Hold the button for 8 seconds and TC turns off completely
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, and meth. Z28 suspension.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff.
Old 10-14-2021, 03:00 PM   #3
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
This would also interest me.
What do each press turn off?
My life is a constant struggle with Camaro.
K&N Typhoon CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, OEM strut tower brace, oil catch can, modified Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, tune from RDP Motorsport.
George-CZ is offline   Reply With Quote
Old 10-14-2021, 03:35 PM   #4
SIM GhostrdrZ
SIM GhostrdrZ's Avatar
Drives: ‘14 Z/28 ‘14 ZL1 M6 vert
The owners/operators manual has a wealth of knowledge
SIM GhostrdrZ is offline   Reply With Quote
Old 10-14-2021, 03:45 PM   #5
Redrockit
Redrockit's Avatar
OK thanks for the info. I still find it confusing that if Stabilitrak is still active in some limited mode, why the display icon saying "off" would be lit.
Old 10-14-2021, 03:52 PM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^^ This. Turns off traction control AND stabilitrac and you better know how to drive well if you have any upgraded power level, even stock HP can get ya into trouble pretty quickly, ask me how I know. lol. This is on my L99. Push the button once and it turns off traction control ONLY and leaves stabilitrac controled by the computer, push it twice quickly and it turns off stabilitrac ONLY and leaves traction control on, no burnouts in this one, hold BOTH down for about 8 secs as Cracka says and you will see both lights shown and you're on your own!! Have fun and be careful!! This is how my L99 works..
Old 10-14-2021, 04:09 PM   #7
kevint
Drives: 2013 1SS
GM probably uses the same dash components across multiple models.
kevint is offline   Reply With Quote
Old 10-15-2021, 05:16 PM   #8
CamaroCracka
You hold the button down and count to 8 Mississippi and all the nannies are disabled. I actually pull a couple fuses at the track so I don't have to think about holding the button and the line lock does not throw any ABS objections that way.
If I am driving on the street, I just leave the nannies in place in case I do something stupid. How the rest of the settings work, I could not tell you.
Old 10-15-2021, 05:32 PM   #9
spyderbuddy
spyderbuddy's Avatar
FYI this also works on the 2010 V6 Camaro Auto
But of Course when in Manuel Mode you better know when to shift
or you will redline the Engine The Auto will not Shift in Manuel Mode till you tap a paddle
BBK Headers & High Flow Cars, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
Old 10-15-2021, 07:15 PM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Totally different thing than what is being discussed here. lol. We're talking traction control and stibilitrac, not the "manual" shift mode in the auto trans..
Old 10-15-2021, 08:01 PM   #11
spyderbuddy
But I am talking about the Stabiltrac and Traction Control
FYI That hold down the buttons for 8-10 sec also Works on the V6's
My First part WAS FYI This Also Works For the 2010 V6 Auto, it's not just a V8 Thing
Old 10-15-2021, 10:28 PM   #12
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
2 taps will put you in competitive mode. The TC will be lit on the 1st tap, stabilitrac will not be lit. Second press stabilitrac will be lit, TC will not be lit. Long hold the button, 8 to 10 seconds, and both will be lit. If both are coming on for you with 2 taps, something is wrong. Or at least different than mine. Post #4 is interesting. Anyways, 95% of the time, I long hold and drive with all the nannies turned off.
N.O. Plate(dedicated fuel tank, progressive, fuel hose upgrade, remote opener, heater, console switches), LNC2000, CTAP, ARH 1 7/8" LTs/gutted cats/X pipe/mufflers, Jet Hot coated LTs, JRE SCT Tune, CAI, Scoop, Rx Catch Can, Gates heater hose relocation, Remote clutch & auto brake res, Metco loop, Momentum Tunnel Brace, TSW Nurb 18" 555 & 05, Pfadt trailing arms & toe rods, Autometer WB, Fesler Pillar Pod, LED strips (int), Lloyds floor & trunk mats, LED DRL/front turn & license plate, DRL harness, VLEDs tail lights, Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 10-15-2021, 11:58 PM   #13
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM 2399
Lol no shit. First time I tried it i was skeptical the nannies were all the way gone… went to an empty parking lot and slid it sideways for a good 50-60 yards controlling the steering with the accelerator pedal, and rolling smoke off the tires. I had my hands full a little more than I expected. I was glad to know that you can make the nannies fully disappear if you want.
”Blue”ABM #2399, 2010 2SS/RS: GM GFX, GM Heritage, GM dovetail, Silver Ice Rally stripes.
‘87 IROC-Z loaded 50K mile survivor. IROC blue TPI 305/700R4 long term project
Aqua Blue RS/SS is offline   Reply With Quote
Old 10-16-2021, 07:48 AM   #14
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2017 Colorado, 2013 2SS
Sounds like the car is broken. Send to me, I fix.
Some misinformation in this thread about getting into competitive mode. Be careful out there guys.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is online now   Reply With Quote
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
