06-14-2018, 05:43 PM | #1 |
Drives: 2017 2SS Convertible Join Date: Apr 2017
Charging pad upgrade works perfect! iPhone X charging in 2017
For anyone interested - i posted a message a couple weeks ago about installing the updated charging pad in our 2016s and 2017s.
The part is 84526978, it is a direct replacement part, that fits perfectly in my 2017. A harness adapter is needed, but it is included with the part. To install: remove center console and shift knob (4 10mm bolts up front behind knee pads, 2 10mm bolts behind covers located low in the back seat area, need to move seats all the way forward to get to them) I did not even have to remove the console, I just sat in the back and lifted it up from there. 4 torx head screws hold the pad in. GET IT, works perfect!
2017 2SS, Hyper Blue, 8sp, NPP, MRC |
06-14-2018, 05:50 PM | #2 | |
Drives: 2017 GRT 2SS/RS M6 Vert Join Date: Jan 2014
If it were more fun, it would be illegal!
06-14-2018, 05:55 PM | #3 |
Install was so easy too, literally took 20 minutes, and I took my time.
When removing the knee pads, use a trim tool at the bottom of the pad, they lift straight up. The shift knob is just pushed on, no screws holding it on, just lift straight up. I did not remove the boot from the knob. The console does not need to be removed, I just got it all loose and lifted from the back. super easy!
06-14-2018, 07:07 PM | #4 |
Any pictures of the upgraded setup? Seems like a cheap, reasonable upgrade.
Gone but not forgotten:
1998 Bright Purple Metallic Camaro 2012 Carbon Flash Metallic 2SS Convertible 2016 Summit White 2SS Coupe M6, NPP, & MRC Now Driving: 2016 Torch Red Corvette 2LT, NPP, MRC |
06-14-2018, 07:11 PM | #5 | |
The pad is almost identical to the gen 1 pad. Everything fits perfectly, no modifications needed at all (other than the included harness that is plug and play) I got mine for $75 shipped from gmpartsgiant.com
06-14-2018, 07:27 PM | #6 | |
Drives: 2004 Corvette / 2017 2SS Camaro Join Date: May 2016
What phone will fit in it? Iphone X, Galaxy Note 8, etc.
You really need pictures. Quote:
06-14-2018, 08:07 PM | #7 |
Drives: 2016 2SS Camaro fully loaded. Join Date: Nov 2016
Can we see pics of it now at least? And of it compared side by side to the old one?
06-14-2018, 08:15 PM | #8 |
damn, wish I had taken pics now... only pic I have is of the screen showing the charging bolt.
06-14-2018, 08:30 PM | #9 |
took a few - hope it helps, top pic is the new one installed, bottom is old one
2017 2SS, Hyper Blue, 8sp, NPP, MRC Last edited by speedup; 06-14-2018 at 08:53 PM. |
06-15-2018, 08:35 AM | #10 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Is the X really small enough to fit in the charger spot? Regardless of charger my note 8 isn't fitting in the spot.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap Last edited by ICTsccaCamaro; 06-15-2018 at 01:59 PM. |
06-15-2018, 08:40 AM | #11 |
iphone x lays flat without the case. I have an otterbox symmetry case that does not let it sit perfectly flat, but it still charges like this, even with case on
06-15-2018, 01:02 PM | #12 |
Drives: 17 2ss vert Join Date: Dec 2017
So this is the piece we need to upgrade? https://www.gmpartsdirect.com/oem-pa...e-pkg-84526978
06-15-2018, 01:04 PM | #13 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
obviously this is for the people who dont plug in for android auto or carplay. So this is not a feature i could utilize so I haven't.
But my suggestion for those who do find this as a useful feature, to get off the idea of making this charging pad horizontal to fit inside the tiny length and width of the cubby area. You can charge while the phone is vertical or learning on an angle. This gives you much more flexibility in phone sizes without really impacting convenience (it's almost definitely more convenient than laying flat). I made a vertical pocket out of some fiberglass for my phone. Adding wireless charging to the pocket would be trivial. Then it would fit any phone without risking it falling out. |
06-15-2018, 01:11 PM | #14 | |
