05-31-2021, 05:44 PM | #1 |
Drives: 13 AshGray M6 ZL1 w/Nav/ECF/Sunroof Join Date: Aug 2012
Help: Sport Tour button modes won't work anymore
My 2013 ZL1's Sport and Tour modes will no longer activate. The car only has 15,000 miles and I've noticed the suspension now feels like a land yacht. I've tried unplugging the battery to reset the computer and I know I'm not in one of the 5 PTM modes which will deactivate the lights. Could my Magneto shocks have just gone bad from having the car sit so long? When I first put in and turn the key the Tour or Sport mode light will turn on for a sec then turn off so I know the lights work, but then when pushing either button it will not turn the light back on. I'm not getting a fault code for the shocks and I've run the OBDII with no codes either. I really hate to take it to the dealer so am hoping someone here has seen this before, thanks.
05-31-2021, 07:10 PM | #2 |
Drives: 2013 ZL1 Join Date: Mar 2013
You said you unhooked the battery but for how long? That usually will take having the battery unhooked at least 12 hours [overnite] then hook it back up and it should correct itself. If not check your fuses one may have blown. Good luck.
05-31-2021, 07:34 PM | #3 |
Thanks, I saw a tread on here for a related PTM issue that said to unplug the battery for about an hour, but will try it again overnight now. I had looked up the fuses closely in the owners manual but could not find one that could be related to this issue, maybe I just need to look again.
05-31-2021, 07:38 PM | #4 |
Drives: 2014 ZL1 Join Date: Jun 2009
Magrides are shot. Replace them with coilovers and thank yourself later.
2014 ZL1 M6: Roto Fab Intake, LS3 TB, Long Tube Headers, NPP, Mild 2 Wild, JMS BAP, SMG aux pump, ID 1050X Injectors, DSX Flex Fuel Sensor, 10.5" DSX Lower Pulley, Killer Chiller, Tuned by Ted at JRE, Pedders XA Extreme coilovers, Mickey Thompson Street S/S on Weld S71s
05-31-2021, 08:39 PM | #5 |
Drives: 2013 AGM ZL1, '70 Chevelle 454 Join Date: Apr 2019
Hey Shodown, I saw your signature and very impressed with your numbers. Making 633 hp with a 10% pulley and headers is very impressive. Does the chiller play a big role in making that power?
Sorry, not trying to hijack the thread. Let us know if disconnecting the battery for 12 hours works! |
05-31-2021, 10:12 PM | #6 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
06-01-2021, 02:14 PM | #7 |
Drives: Chevrolet camaro zl1 Join Date: May 2019
Agree. Unhook the battery overnight before replacing the mag rides
2014 Sliver ZL1. Built engine, Stage 1 Frankenstein heads, Magnuson, SW long tubes, AFCO H/E, She Gone cam, flex fuel sensor, meth injection. 820rwhp e85.
06-01-2021, 06:21 PM | #8 |
Well overnight didn't work, still having the same problem. When I put the key in and turn it the Tour or Sport mode light will just blink once then will not turn back on after selecting the buttons.
06-02-2021, 06:15 AM | #9 |
Dang I was hoping that would fix it.
06-02-2021, 12:11 PM | #10 | |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
06-02-2021, 08:00 PM | #11 |
06-03-2021, 03:05 AM | #12 | |
06-04-2021, 10:28 AM | #13 |
Drives: 2012 ZL1 Join Date: Apr 2015
You need to get the BCM refreshed, there could be an update as well. I had the same thing happen to me after my battery died over winter storage , tried everything but it didn't work... luckily my cousin is a tech for GM and was able to reflash it for me , after that it was back to normal! Also your speed is limited while your suspension has no tune ..
2012 ZL1 preproduction car #13 ROTO-FAB intake / IC reservoir , 2.85" upper , ported inlet |
06-06-2021, 01:09 PM | #14 |
How do you reflash the BCM?
Yes this happened after the battery went dead on me. |
