11-01-2018, 07:23 PM | #1 |
Drives: 2017 1SS 1LE Join Date: Dec 2014
Blade spoiler removal
Just a quick question to anyone who may know.
Anyone know a safe way to remove the two pieces of the blade spoiler that are on the body? |
11-01-2018, 07:35 PM | #2 |
Drives: No Camaro :( Join Date: Apr 2013
I would start with some floss. Thought the ends were just double sided taped on by the dealers.
11-01-2018, 07:55 PM | #3 |
Drives: '18 1SS 1LE Join Date: Sep 2017
Careful use of a heat gun might make it a little easier.
'18 1SS 1LE Black, PDR
11-01-2018, 09:14 PM | #4 |
Drives: 08 Tiburon GS, 2018 Camaro 2.0T Join Date: Sep 2017
A saw a thread recently talking about that... I'll try to find it.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
--------------------- Order WDGHKX 1100 - 5/08/2018 | 3800 - 6/18/2018 2000 - 5/09/2018 | 4200 - 6/21/2018 3000 - 5/28/2018 | 5000 - 6/27/2018 6000 - 6/29/2018 |
11-01-2018, 09:17 PM | #5 |
11-01-2018, 09:53 PM | #6 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
The end caps are put on with two sided tape, but also some dealers are using a cement. You need to saw them off , but better than floss is #20 or 30 pound fishing braid line, be careful , it'll cut your fingers. Buy a medicine dropper and keep putting Googone on every 10 minutes for an hour , so it soaks into the center of it, then use the braid to saw it off.... I've done two of them, they can be a bitch.
11-02-2018, 01:30 PM | #7 |
Daily Driven 1LE
Drives: 2018 1SS 1LE Join Date: May 2018
Mine looked like absolute crap how the dealer mounted them. I sprayed some goo gone underneath and then used dental floss to cut through the double sided tape.
2018 1SS 1LE
11-05-2018, 11:22 AM | #8 |
You getting a new trunk lid for the new spoiler due to the different mounting holes?
11-05-2018, 01:20 PM | #9 |
Drives: 2023 2SS, 2018 1SS 1LE, 1993 Z/28 Join Date: Jun 2018
The thin double-sided tape is for positioning only. The official instructions also include sanding the paint to knock off the gloss (if the spoiler wasn’t installed on fresh paint at the factory), plus using adhesive promoter and special trim adhesive.
11-05-2018, 01:25 PM | #10 |
We just went through this for a guy with a standard SS who wanted to change to a 1LE spoiler. All the necessary holes for either type of spoiler are already drilled in the trunklid at the factory. The ends of the 1LE spoiler section that mounts to the trunklid even extend forward slightly to cover the holes from the original spoiler. And as described above, the end caps on the rear fenders are not just a peel-and-stick installation.
11-07-2018, 05:30 AM | #11 |
Yes sir.
11-07-2018, 05:34 AM | #12 |
11-07-2018, 05:50 AM | #13 |
Cool.
Glad to see the job allows you time to make videos again, missed the content for a little while. Hope the new position at work is going well. If you get a chance could you weigh the trunk lid? There's another member working on weight reduction and was looking for the weight of some stock parts, trunk lid included. https://www.camaro6.com/forums/showthread.php?t=541738 Thanks, and looking forward to next season to see how you and your car progress on the track.
11-07-2018, 07:05 AM | #14 |
It came early, now I have to wait to unwrap the presents. I'm not in any way mechanical and have to wait till my installer gets back into town (2weeks) for him to wrap the trunk, then put the stripes on it and put the wing on. The difficult part will be removing the two pieces of the blade spoiler that's on the body. That's why I'm not doing it myself.
