11-12-2019, 09:39 AM | #1 |
Drives: 2012 Camaro 2SS Ls3 Cammed/Blown Join Date: Feb 2016
Where is the reverse lockout solenoid???
My 2012 Camaro ss manual won’t shift into reverse. No check engine I’m assuming it’s the reverse lockout solenoid I just don’t know where it is.
11-12-2019, 10:18 AM | #2 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
On the transmission. The tailshaft section near the shifter. There is the reverse lockout and the CAGs solenoids.
More to come. Last edited by Black_SS10; 11-12-2019 at 10:40 AM. |
11-12-2019, 10:22 AM | #3 |
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM |
12-30-2019, 06:07 PM | #4 |
Finally got around to replacing the reverse lockout solenoid and I still have the same problem
12-30-2019, 07:16 PM | #5 |
SomeguyK
Does it not physically move into reverse? Is it grinding?
More to come. |
12-30-2019, 07:28 PM | #6 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
What is it doing/not doing?
12-30-2019, 07:45 PM | #7 |
Doesn’t grind or anything like that when I shift into reverse there is a lot of resistance/have to push a little hard but once it’s in gear everything works normally. I’ve been using it like that for a while.
12-30-2019, 08:46 PM | #8 |
Could be a synchro starting to go bad.
12-30-2019, 09:16 PM | #9 |
Onyx_Z7 <— Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
Had the same issue it was a bitch to put in reverse. Make sure it’s plugged in all the way, my reverse lockout was a little loose.
12-30-2019, 09:21 PM | #10 |
Drives: 2014 1ss camaro Join Date: Jul 2017
if you changed the solenoid, and its hard to get in gear without grinding. then its further up the control circuit. I recall reading about the same problem you have on ls1tech forums with the same problem on the t56. look there. on my t56 back in the days of yor I had liberty's gears take the whole reverse syncro's out. that required the car to be at atotal dead stop before it would go in gear. that's what I wanted. you don't want it to in reverse while moving forward anyway.
12-30-2019, 09:24 PM | #11 |
SomeguyK
It may be the reverse synchro or shift fork. I'm leaning towards synchro. Reverse is the only gear you're having trouble with? Do you do a lot of high speed 5th shifts?
More to come. |
12-30-2019, 09:25 PM | #12 |
when I get ready for a clutch, I will be doing the same to this one. they make blank plugs to take place of the solinoids. I forgot where I got them it was a while ago. the oldman...........
12-31-2019, 03:20 PM | #13 |
The car only has 29000 miles so I doubt it’s an internal parts issue in the transmission
12-31-2019, 05:33 PM | #14 |
SomeguyK
Mine had around 31000 miles when I rebuilt my trans. The synchros, especially 2nd, showed signs of wear. It can only be so many things...synchro, gear, shift fork, lockout solenoid, or something else internal. Remove the lockout solenoid completely and see if there is any change.
More to come. |
