#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 03-27-2017, 05:52 PM   #1
NY Andrew
NY Andrew's Avatar
Drives: 2016 Camaro V6 2LT RS Fully Loaded
Question Loose Door Key Cap??
I've had to jumpstart my car recently and remove the drivers side key cover to manually unlock the door. I've done it in the past with no issue, it seemed to lock back in, but I think since the last time the dealer had it for two weeks they made it worse... The piece is now loose... It still has the circle intact, not sure if it's connecting to anything inside, but seems like the external plastic part isn't locking because it rattles with slight tap and doesn't sit tight like the passenger side does.. Unsure if there's little clamps that go on the edge to maybe grip the outside to prevent the rattle, but even once I slide it in it still seems to wobble, not sure how to lock it in correctly..
Any suggestions on all this? Would love to save another trip to the dealer after they sat on a couple issues for two weeks.. Thanks!!
Borla ATAK w/ Midpipe, VMAX TB, K&N Filter, Subwoofer, Tinted, AFM Disabler, Vitesse Throttle Controller!
ORDERED:08/19/15 DELIVERED:12/09/15
My 2LT Review/Pictures/Mustang Comparison
My 2016 Camaro Bose Subwoofer Install
2016 Camaro V6 Stock to Borla Atak Exhaust Sound
2016 Camaro V6 Resonator & X-Pipe Replace with Midpipe & Borla Atak
NY Andrew is offline   Reply With Quote
door, key
