Old 06-23-2014, 07:02 AM   #1
KARBON
KARBON's Avatar
Drives: 2010 CAMARO 850 RWHP/733 RWTQ
6L80 to TH400 Swap
Well finally the day is here. Lethal Racing will pick up Whitey and start the next stage of transformation. After 3 years and 2 6L80 transmissions go bust. I am finally going to get rid of those POS 6L80's that love to flare shift. A list of parts for the swap.
RPM Stage 6 TH400 w/Trans brake and rev manual valve body.
Precision custom torque converter (3600 stall)
SFI Bell housing
B & M Pro shifter
B & M trans cooler w/ Fan
Custom drive shaft
GForce 1500 H.P. axles
BMR diff bushings
BMR drive shaft loop
*Night Fury
*Vortec YSI
*Alky Meth
*RPM TH400 with Brake
*Precision 3600 Converter
*850 RWHP/733 RWTQ
KARBON is offline   Reply With Quote
Old 06-23-2014, 01:43 PM   #2
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
Man that a good set up for the track. I take it that you want be doing much highway driving.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 06-23-2014, 06:04 PM   #3
KARBON
KARBON's Avatar
You are right not much highway driving. Won't be to bad though, should turn about 2600 @ 70
*Night Fury
*Vortec YSI
*Alky Meth
*850 RWHP/733 RWTQ
Old 06-23-2014, 07:02 PM   #4
Mr. Nasty
Mr. Nasty's Avatar
That a little better then my 68. I have a 502 in it with the TH400 @55 to 60 am at 2600 rpm.
Old 06-24-2014, 03:27 PM   #5
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
That's a lot of power on the stock block. Any track times?
DarkCry956 is offline   Reply With Quote
Old 06-24-2014, 06:37 PM   #6
KARBON
KARBON's Avatar
Not yet but soon. Been fighting trans problems since installing the YSI. I have it set at 700 RWHP @12 PSI. The 850 RWHP @17 PSI pull was just to see what she would do.
*Night Fury
*Vortec YSI
*Alky Meth
*850 RWHP/733 RWTQ
Old 06-24-2014, 10:49 PM   #7
DarkCry956
DarkCry956's Avatar
Sounds about right. I had 720 through the 6L at 13psi and lots of issues w the trans. 4L is the way to go
Old 07-13-2014, 11:00 AM   #8
KARBON
KARBON's Avatar
Well TH400 by Lethal Racing is complete. Really looks like a factory install ! Top notch work by Nick and crew. Car drives great and I am having fun shifting the manual valve body. Took her on a hour highway drive to Cars and Coffee an hour away in Baton Rouge the day after picking her up. All went great and turned 2700 @ 70 MPH. Iron out a few more nick nacks and off to the track we go !!!
*Night Fury
*Vortec YSI
*Alky Meth
*850 RWHP/733 RWTQ
Old 07-13-2014, 12:11 PM   #9
Mr. Nasty
Mr. Nasty's Avatar
Looks good that the same trans cooler am using. How did you get it work on the front of the bumper?
Old 07-17-2014, 06:55 AM   #10
KARBON
KARBON's Avatar
I really dont know, Lethal did the install. I can tell you that the fan is only about 1/8" away from the front bumper skin. Really close but it fits
*Night Fury
*Vortec YSI
*Alky Meth
*850 RWHP/733 RWTQ
Old 07-17-2014, 07:00 AM   #11
KARBON
KARBON's Avatar
*Night Fury
*Vortec YSI
*Alky Meth
*850 RWHP/733 RWTQ
Old 08-22-2014, 11:21 PM   #12
Silver Ice Man
Silver Ice Man's Avatar
Drives: 2014 2SS/RS Spring limited edition
This is pretty much what I am looking to do with my manual 6 Speed
Drop it and put in the turbo 400.
How much modding do you think there will be to make it work?
Thanx
2014 2SS/RS, Spring Limited Edition...
Ask yourself.....when you turn on your car..... Does it return the favor.....
MODS: CIA cold air intake, Oil catch can, Dynatech LT Headers, Dynatech Power cats, Dynatech Cat back exhaust, Janetty racing tune, Vitesse throttle controller, Headlight and marker tint, more to follow....
Silver Ice Man is offline   Reply With Quote
Old 08-26-2014, 12:45 PM   #13
jam3
jam3's Avatar
Drives: 2010 camaro ss
What gear you running??
jam3 is offline   Reply With Quote
Old 08-26-2014, 03:01 PM   #14
KARBON
KARBON's Avatar
3.23's
*Night Fury
*Vortec YSI
*Alky Meth
*850 RWHP/733 RWTQ
