10-19-2015, 04:57 PM | #1 |
Vroom
6060 to th400
Looking for any pointers or tricks when swapping from a 6060 to a th400.
Any info will be appreciated. Thanks in advance.
LSX, Boost, 9", TH400
xxxxhp - xxxtrq |
10-19-2015, 07:56 PM | #2 |
Vroom
And if any vendors have complete swap kits please feel free to PM me, I haven't 100% decided on whos tranny I'm going with
xxxxhp - xxxtrq |
10-19-2015, 08:01 PM | #3 |
Drives: 2010 2SS/RS Join Date: Dec 2009
What are you going to do with the 6060???
10-19-2015, 08:14 PM | #4 |
Vroom
It will be getting sold along with the mcleod rxt to help fund the th400.
xxxxhp - xxxtrq |
10-20-2015, 01:15 PM | #5 |
Drives: 416 w/TH400 Join Date: Mar 2012
I did the 6l80 swap to TH400 and that's harder so I should be able to help ya out give me a call
ERL 416 - 12.5 cr, TH400, Custom VVT Cam, PRC 255 heads, NW 102 TB, Aeromotive stealth fuel system, Fast 102 plumbed with a nitrous express direct port kit, BMR 15" conversion kit
03-13-2016, 06:41 PM | #6 |
Drives: 2012 Camaro 1LS w/L99/TR6060 Join Date: Dec 2012
Interested in your tr6060
03-13-2016, 06:49 PM | #7 |
bcguy
Drives: 2011 ss/rs m6 Join Date: Nov 2011
Pretty easy. You will need a different flex plate , drive shaft (drive shaft shop has all measurements on hand so they can help you with that ) your Trans crossmember will work with a bit of modifieing and need a Trans mount . Don't forget shifter also , Trans oil cooler. Then just figure out your neutral safety switch wires and reverse lights. Search turbo 400 swap should have a bunch of pict to help
Agp 62/66 ,lsx 427. , Callie's ,diamond ,all pro ,American racing ,I'ds130s,102 intake and throttle body,etc .fore triple , Turbo 400 level 5 , b and m pro , dss carbon fiber , dss ford 9 inch with strange pumpkin,3.73 ratio,1400 hp axels,boost and air fuel pillar guages. Weld rts 17x10 and 17x4.5 with m and h drag radials and skinnys
04-10-2016, 12:23 PM | #8 |
Bump
04-11-2016, 11:04 PM | #9 |
Vroom
Swap went fairly smooth, pretty much as had figured honestly.
xxxxhp - xxxtrq |
04-12-2016, 12:47 AM | #10 |
Figured as much. I'm about ready to do the deed.
What about reverse lights and neutral safety?
04-12-2016, 07:20 AM | #11 |
10.11 @ 136.32
Drives: Black & Yellow 2SS/RS LPE LS7 427 Join Date: Mar 2010
I went to the solenoid on the starter and cut the purple wire, then ran 2 wires off the neutral safety microswitch on the shifter down to the starter and connected each to one side of the cut purple wire.
I think guys doing the swap from the 6060 have the reverse lights figured out but not the case going from the 6L80.
04-12-2016, 05:38 PM | #12 |
Anyone figure out cruise?
04-12-2016, 11:59 PM | #13 |
10.11 @ 136.32
I think everyone came up empty on that one too.
04-13-2016, 02:28 AM | #14 |
I need to look at the schematic.
