03-09-2016, 08:26 AM | #1 |
Drives: 2016 2SS A8 Convertible Join Date: Aug 2010
E85 plus meth???
Running a Magnuson tvs2300 on top of my 427 with ETP 245 heads. Have been running meth for a few years. No issues. Recently made the switch to E85 and upgraded the fuel system to handle it. Also added an E85 / flexfuel sensor.
Currently have the meth turned off. But noticing the iat's climbing during some hard pulls. Anyone using E85 and still spraying meth? Pro's vs. con's? edit.... I am using: An upgraded intercooler http://www.summitracing.com/parts/afc-80275ndp An upgraded coolant tank http://www.summitracing.com/parts/mor-63494 Dual spal fans on the upgraded radiator. I also have a killer chiller system that can also be used. I have seen it make frost on the lines. Last edited by tom's2005gto; 03-10-2016 at 08:07 AM. |
03-09-2016, 09:18 AM | #2 |
I am. It was recommended to me by my builder.
Jennetty started a thread in here and I asked his feedback, he advised against it. ( I'll see if I can find his response.)
Taco's 2014 SS
Mods: 417 Stroker | CAI | Bo's PTB | Kooks LTs | Flowmaster Outlaw Catback | Night Fury Cam | Powerbond UDP | Apex Catch Can |PRC Ported Heads |FAST 102 Intake |Suspension Crap| Built by J-Rod. |
03-09-2016, 09:22 AM | #3 |
Here's Ted's reply.
Taco's 2014 SS
03-09-2016, 09:32 AM | #4 |
Vroom
E85 and 50/50 meth here.
LSX, Boost, 9", TH400
xxxxhp - xxxtrq |
03-09-2016, 10:35 AM | #5 |
Really, Really Fast
Drives: 2010 Camaro SS Join Date: Feb 2013
e85 and 100% meth here
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
03-09-2016, 10:49 AM | #6 | |
Your limitation is your blower and the size of the intercooler brick the temp will climb simply due to the fact that your overwhelming the intercooler brick. Move to a Whipple 2.9 and you can pick up 100 RWHP and have lower IAT to boot due to the larger intercooler brick. Distribution can be a problem spraying through a blower. Ted.
www.jannettyracing.com
03-09-2016, 11:07 AM | #7 |
Drives: 2014 Camaro 2SS 1LE Join Date: Jul 2015
On my race car E85 plus 75% methanol and 32psi boost
AGP TT 807whp 811wtq 13.46psi E85+methanol
03-09-2016, 11:43 AM | #8 |
ЯєŧąяĐ Єl¡m¡иąŧøя ™
E85 and meth here
03-09-2016, 04:24 PM | #9 | |
Drives: 2011 Syn Green Camaro Join Date: Sep 2010
New Build
5th Gen Camaro, 430ci LSx, Ported Mast 280's, E85 Flex fuel, ID1300's, Squash return, TVS 2300 w/Nitrous Outlet 250 Shot Direct Port, Nano, LPE 10/14 Rib, OD Crank, OD Rear, 2.8" upper, RDS Plate, NW102, 5" Intake, 2" ARH, PATC Built A6, BMR 15" Brake Conv. w/Drag Suspension, Front QA1 DA's, Weld S76 beadlocks & "V" Series fronts. STILL 1k too heavy!!! |
03-09-2016, 10:05 PM | #10 |
Drives: 2012 CTS-V, 2010 Camaro SS Join Date: Sep 2013
Upgrade your intercooler.
2012 CTS-V: Cosmetic Chute. |
03-10-2016, 08:09 AM | #11 |
Good info guys, I do appreciate it. op updated with more details about current cooling system etc.
03-10-2016, 08:27 AM | #12 | |
Liquids need time to turn from a liquid to a vapor to a gas before entering the cylinder, there are so many variables it would be impossible to predict. Ted.
03-10-2016, 10:06 AM | #13 |
Dose it not help to seal the rotors or cool the air charge ?
Forged LS3 416ci, Maggie TVS2300 @ 13lbs boost, McCleod twin disc clutch, GForce 1320 nine-inch 389 gear ratio, Hurst line-lock, 750 whp 700 wtq |
03-10-2016, 01:16 PM | #14 | |
"Distribution can be a problem spraying through a blower." Can you explain what kind of distribution problem the blower causes? I know the thread was about meth but would nitrous be any different. I have been spraying approx. 175-200 shot through my current TVS setup but in the process of a new LSx build. What problems does spraying through the TVS pose? I am not trying to argue the point but really would like to know. I understand that with the required fuel that the nitrous requires there must be some point of saturation where the wet shot fuel/air mix has to come into play as the blower/manifold was designed for air only. Could this lead to an unforeseen problem? I will be throwing lots of cash at this next build and planned on even more nitrous.
New Build
