Old 06-22-2018, 07:19 PM   #1
Abdi
Drives: 2013 1LE
NPP exhaust quiet down
Hey guys/gals,
I would like to temporarily close the valves in the NPP exhaust system this weekend. I'm running an HPDE and I'll be at a track with lower than usual sound decibel restriction. It's too late for me to order a mild to wild switch (I'll get one next week) and I'm afraid I'll get blacked flagged for the weekend. I currently have ARH long tubes w/high flow cats so it gets pretty loud at WOT.
Would disconnecting the vacuum lines to the mufflers close the valves and keep them closed?
I'm heading to circuit Mount Tremblant in Canada. Max is 92db on A scale 15 meters from track edge.
Watkins Glen which I do often has no sound restriction.
Any help is appreciated.
Cheers,
Abdi
Abdi is offline   Reply With Quote
Old 06-22-2018, 07:34 PM   #2
Leo72793
Drives: 2011 2SS/RS
Answer: NO. That keeps them open all the time.
IF you have NPP and it wasnt part of the car from the factory a M2W switch does nothing for you as you dont have the required pieces for it.
I made my own switch using a few parts. Not cost effective imho.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
Old 06-22-2018, 07:42 PM   #3
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Laguna pipes? Lol
DSX_Camaro is offline   Reply With Quote
Old 06-22-2018, 07:46 PM   #4
Abdi
Drives: 2013 1LE
Thank you.
Sorry, the NPP option was from the factory. I might have try to make my own M2W switch tomorrow morning if I can find the parts.
Old 06-22-2018, 08:25 PM   #5
608RS
608RS's Avatar
Drives: 2015 2ss
if you want the ability to close the mufflers, you'll want the Forza Model E2 Controller. That's what i have, it's a very good product. Forza is also a sponsor here.
http://www.forzacomponenti.com/exhau...troller_e.html
2015 Camaro 2ss, NicKey Performance built/tuned
608RS is offline   Reply With Quote
Old 06-22-2018, 09:08 PM   #6
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
I did this...
https://www.camaro5.com/forums/showp...44&postcount=9
Old 06-22-2018, 10:52 PM   #7
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
I did the same thing as larry, works great and I think I spend $10-$15 dollars for the switch and wire needed.
760bowtie is offline   Reply With Quote
Old 06-23-2018, 07:39 AM   #8
JD555
JD555's Avatar
Drives: 2014 2SS RS, 6 sp man
Temperately mechanically wire the valves in the closed position.
JD555 is offline   Reply With Quote
Old 06-23-2018, 03:15 PM   #9
Leo72793
Drives: 2011 2SS/RS
Originally Posted by Abdi View Post
Thank you.
Since it was from factory the M2W will work. Those that added NPP 2nd hand, can not.
Old 06-23-2018, 06:02 PM   #10
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
I just finished wiring in a 3 position switch this morning. I definitely recommend it. The longest part of the job is running the wires up front. Works great. I did it because I leave at 4:45am for work and after my header install the noise is too much for my neighbors lol.
Sent from my SM-N950U using Tapatalk
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 06-24-2018, 04:17 AM   #11
Pete G
Pete G's Avatar
Drives: 2015 SS 1LE
The mild to wild controller keeps the muffler open all the time and not closed all the time like you are looking to do
Pete G is offline   Reply With Quote
Old 06-24-2018, 08:59 AM   #12
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
You will need the Forza 3 way controller or hard wire a switch.
Just for reference sake....... stock headers, solo high flow cats and NPP (open/WOT) is around 97-98db. My car measured 97.4db at an autocross event where the DB limit is 101.
Old 06-24-2018, 05:43 PM   #13
Fish-man
Drives: too many to say!
10min fix for my NPP exh on my non NPP car... removed the vacuum valves and bought bolts that thread into the joint that pivots the valve. Washers and nuts on the other end
Fish-man is offline   Reply With Quote
Old 06-24-2018, 06:26 PM   #14
Abdi
Drives: 2013 1LE
Everyone,
Thank you for all the inputs! Looks like I have a couple of different options. I'll let everyone know what I did and how my weekend turned out on Wednesday. I have the wife and kids with me and we are spending a couple of extra days checking the lake, mountain and local attractions.
