Old 03-31-2016, 03:29 AM   #1
z28guy30
z28guy30's Avatar
Drives: 2016 camaro 1ss
OHC vs OHV fewer moving parts
I have seen a couple people on this forum claim that an OHV engine has fewer parts than an OHC engine, but to my knowledge it is the opposite. An OHC engine does not have valve lifters, pushrods, and in some cases rocker arms. If they are referring to a 32v DOHC such as the 5.0 coyote they may have a point due to the extra valves, cams, and rocker arms.
z28guy30 is offline   Reply With Quote
Old 03-31-2016, 06:02 AM   #2
NC_SS
NC_SS's Avatar
Drives: 2012 M6 Camaro SS (RIP)
OHV does have more parts, and to my knowledge that's mostly why it limits how high a pushrod engine can rev.
Hence why people salivated over the fact that GM got the LS7 to pull to 7K
Push rods push Gods
NC_SS is offline   Reply With Quote
Old 03-31-2016, 07:06 AM   #3
rdavis
Drives: 2012 SS
One of the reasons that I traded my 13 5.0 for my 12 SS is the simplicity of the LS engine. The 5.0 is a screamer of an engine, but very complicated. became out of warranty,so if it broke I was walking. The 5.0's have 4 cams 4 timing chains, cam phasers on each cam. 32rocker arms 32lash adjusters. They do have more parts than an LS motor.
rdavis is offline   Reply With Quote
Old 03-31-2016, 07:15 AM   #4
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
Oh no, not this again....
Thor142 is offline   Reply With Quote
Old 03-31-2016, 10:00 AM   #5
jcampos
jcampos's Avatar
Drives: 2014 Chevy Camaro SS
+1
jcampos is offline   Reply With Quote
Old 03-31-2016, 10:04 AM   #6
drew peacock
Banned
Drives: 2012 2SS INFERNO ORANGE
32 valve 4 cams 2 camchains..all ok untill something goes wrong then your left with a huge repair bill.
drew peacock is offline   Reply With Quote
Old 03-31-2016, 10:09 AM   #7
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Different strokes for different folks. They both make great power when done right.
9/26/09 Took delivery!
Old 03-31-2016, 10:31 AM   #8
thegreatwhite
Drives: 2014 SS
yessssss love this debate
thegreatwhite is offline   Reply With Quote
Old 03-31-2016, 11:13 AM   #9
Thor142
Thor142's Avatar
Like when an oil pump fails on an LS3? Or the valve train fails on an LS7? More parts don't mean more failures. You sound like those old guys that warned us about fuel injection back when carbs were being phased out. "All that electronic shi*t is just going to fail!" Catastrophic failures generally cost a fortune no matter where the cam or cams are in your engine.
......aaaand I got sucked into this again.
Old 03-31-2016, 11:17 AM   #10
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Both OHV and OHC have been around a long time. It's not so much which set up is being used that creates a problem as it is the RPM levels any engine is built to reach. RPMs kill engines. Longevity and reliability drop off quick as you spin the engine faster and that applies to both OHV and OHC. IMO, what is the use of being able to spin the valve train at 10k if the rods blow out the bottom end.
Rather than spin the hell out a smaller engine, I prefer to increase displacement or add boost. Increased displacement and boost would be the ultimate solution, maybe throw in some nitrous and/or alcohol.
More parts would mean more failures. It's a simple matter of probability. Each part has an average mean time to failure. The more you have the greater the chance one will fail, assuming parts between both engines have similar mean time to failure values.
And all that electronic chit did fail. Fuel injection was on Vettes in the 50s. It took until the 21st century to get it right.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
Old 03-31-2016, 11:35 AM   #11
Thor142
Thor142's Avatar
So go buy a model T and you'll be all set. This debate is so ridiculous I wish I could stay out of it. People just fanboy over one or the other particular type of engine cause that what's in their favorite car. Don't believe me? Go ask this question on Mustang 6g. Modern incarnations of OHC and CIB engines can be fantastic or blow up. Make great power or just turn gas into noise without the by product of horsepower. One is NOT better or more reliable than the other simply based on the "number of parts"
Old 03-31-2016, 11:46 AM   #12
JLSuperfly
JLSuperfly's Avatar
Drives: 2014 Red Hot LS3
+2
JLSuperfly is offline   Reply With Quote
Old 03-31-2016, 12:04 PM   #13
prod
prod's Avatar
Drives: HHR
And then they broke it again with direct injection. There's a more useful topic for debate...
prod is offline   Reply With Quote
Old 03-31-2016, 12:38 PM   #14
CamaroCracka
Personally, I don't see it as a debate. I know how to build a car and know what I like and why I like it. I do find it humorous that people come on a Camaro site espousing the virtues of one of the features of the current Ford motor and get all butt hurt when others disagree and have valid reasons for their disagreement.
