12-24-2009, 01:15 PM | #1 | ||
Original Bumblebee Owner
Drives: 265hp ZX-14, 500hp Silverado, V-ROD Join Date: Apr 2009
Let's talk HP per $Dollar
Since I'm having a problem springing $2,300 for a full exhaust, I'm looking at going a little different direction for the same money and getting much more peak HP gain per dollar spent.
Assuming these things here:
What I'm having trouble justifying to myself is the cost for this common set-up: Yes, I want a full exhaust, but can't accept the cost
12-24-2009, 02:10 PM | #2 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
You've got a $1000.00 investment for a stage 1 cam and installation (15hp).
I would go with a different cam setup if its only going to offer 15hp. I'd rather have set of Long tubes. With long tubes you'll also see much better gains with a cam. |
12-24-2009, 02:27 PM | #3 |
Drives: 2010 RS/SS2 Join Date: Jul 2009
Sounds like you bought the wrong car to go fast with, but its all about what you wanna do. My car picked up 33 rhwp on a $350 dollar tune with no mods at all. With headers and exhaust it picked up 67 hp and made 427/428 to the wheels.
2010 SS/RS SIM
First to run 11's (11.83)on a stock long block. First to run 11's cam only First to run 11's all motor First to run 10's (10.96) and did it with a 100% bonestock long block and a power adder (nitrous) First to run 10's (10.55) on motor in 2010 Camaro First to break into the 5's (5.97) 1/8th mile First to cut a 1.5X sixty foot First to cut a 1.4x sixty foot First to car to cut a 1.3x 60ft |
12-24-2009, 02:37 PM | #4 |
You can also get Texas Speed or Pacesetter headers for about half the cost of the headers you used. To me a cam swap for 15hp is a awste of money, a mild cam can make 40hp easy and a monster can get you 60hp. I agree you don't need a catback, you can do a muffler delete and use a mufflered x-pipe instead.
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. |
12-24-2009, 09:03 PM | #5 | |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
12-24-2009, 09:11 PM | #6 |
Drives: 2010 Camaro Auto 2SS/RS Join Date: Oct 2008
30ish on the headers I can see, but there is no way on God's green earth that you got 33rwhp from just a tune.
Built by Jannetty Racing
670rwhp/649rwtq...Scariness to be determined. Jannety Racing forged 416. TVS2300 Supercharger w/Maggie Max Stage 2, 3.6 Pulley, Innovators West 8 rib conversion, OD rear Cog belt drive. Jannetty Racing Rough Idle Cam, LS3 Conversion. Jannetty Racing built 6l80e Trans, Jannetty Racing Custom Converter, Built rear diff w/ 3.45 gears, DSS driveshaft and 1400 hp axles. ADM Twin Pump Fuel System, ADM CAI, Dynatech 1 7/8" Coated Headers, Borla "S" Catback. Custom 18" Forgestar F14's, Nitto 305/45-18 DR's |
12-24-2009, 09:23 PM | #7 |
Bone stock LS3s make 375 RWHP, LT headers, Cold air kit, Tune makes 420 on average, for a 45 HP Gain average cost with self install and professional tune 2300.00
51 Dollars per HP. Any time you do a cam you need to upgrade the trunions in the rockers, change out the valve springs, retainers and seals, then custom pushrod to maintain 0.050 Preload on Lifters, cost for the parts with gaskets oil, filter and fluids NO LABOR will cost around 1200.00, (I am guessing it is Late) Average gain for a good all around cam 30 Hp but needs another tune or you can do it all together. Cost with no labor 30.00 Per HP. Beyond this it starts getting real expensive. Add Labor and these numbers per HP can double. Ted.
www.jannettyracing.com
12-24-2009, 10:06 PM | #8 |
Drives: '69 SS Convertible Join Date: May 2009
ADM has a Stage I kit that doesn't require the trunions, valve springs, retainers and seals. Andy has a dyno sheet that shows a 20 rwhp gain over stock. He said that is sounds like a stock Cam (which is why I don't want it) so you can probably get by w/o warranty issues. Complete installation is $800.
Don't know much more about it than that because I'm more intrested in his Stage II Cam which is only $1,200 for complete install including a custom tune. Stage II will probably only pick up 30 rwhp (just guessing) but it will sound 10x meaner than the Stage I. One step at a time for me. The Stage II will require headers/exhaust so I'll have to save up for that. I just hope more Mfgs come out with more reasonably priced options. I would love the ARH headers but $2,500 + install on a complete 3" system with Magnaflow. That HURTS!
Build Journal |
12-24-2009, 10:34 PM | #9 |
My car dynoed 360/371 with 114 miles. 115 with a tune it made 393/39x. My tuner is good at it, must be the reason my car ran 12.30's too on the stock 20's.
2010 SS/RS SIM
12-24-2009, 10:34 PM | #10 |
best HP gain for the dollar is headers CAI and underdrive pully. After the good tune you should see about 60hp if that. plus you get a sick ass sound with headers.
12-24-2009, 10:58 PM | #11 | |
I can gain 20+hp without doing anything. Just switch from SAE corrected numbers to uncorrected on a good cold day. Doesn't mean I actually made any gains. Also, my car gained 14rwhp on the dyno without doing anything...took 6 runs for the numbers to stop climbing. Since we're talking about hp/$ what does that come out to? $0 spent 14hp gained. Can't get any better then that. My point is there are plenty of ways to make it look like you gained a bunch of hp when in all actuality you didn't.
12-24-2009, 11:01 PM | #12 |
Maybe you should look at all the fastest list, 6 hp for a tune? Who in the hell picks up 6 hp to the wheels in a tune?
Your a joke man.
2010 SS/RS SIM
12-24-2009, 11:10 PM | #13 |
My check list goes as followed:
First 2010 Camaro to run 11's with a stock long block N/A First 2010 Camaro to run 10's period Fastest 2010 Camaro with a 6 speed and a stock long block Now the only 2 that are faster then me are a 427 F1 car, and a 468 Nitrous car. The only car on the N/A list faster then me is a 427 Auto car, he's not even a half of tenth faster then my current ET. Im not going to argue over BS dyno number's on a stock car, My currnet dyno numbers are 533/493 and 740/770.
2010 SS/RS SIM
12-24-2009, 11:12 PM | #14 | |
2010 SS/RS SIM
Similar Threads | ||||
All the talk about turbos for V6 | trudawg660 | Forced Induction - V6 | 24 | 04-24-2010 12:00 AM |
Want to Talk Camaros with Scott Settlemire? | MTAutoShows | California Meets and Events | 122 | 10-18-2009 10:34 AM |
Suspension guys out there - lets talk wheel hop | Crowley | Suspension / Brakes / Chassis | 14 | 10-09-2009 12:06 AM |
Chevy High Performance - LS3 talk | KILLER74Z28 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 7 | 09-01-2007 02:04 PM |
