![]() Drives: 2015 Camaro 1SS 6M Join Date: Dec 2017
Low effort clutch for SS?
Due to a knee injury that isn't improving, I either need to sell my camaro or find a clutch with much lower pedal pressure.
The Mcleod RST seems to have good reviews, BUT is there anything with an even softer pedal pressure? I don't care much about cost, I'd lose about 8k or worse trading in. I'm willing to pay for a custom triple disc if they are available. The clutch just needs to perform as well or better than stock, grab low/near the floor, and have less pedal pressure. The car is a 2015 SS, no modifications, it's just a fun commuter that sees some street racing and drifting. Currently at 62k miles on the stock clutch, no issues or complains other than my knee pain. Well, and the hydraulics are trash compared to Nissan, but thats a different story.
https://www.camaro5.com/forums/showthread.php?t=574471
And yes, I read this and many other similar threads. The problem is, not many people desire a softer clutch, the factory one is quite soft. I guess my two concerns are: pedal pressure, and travel. Reducing both would be ideal. Thank you in advance, I know this is "mostly covered" but not for my exact needs.
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
If you do find a "softer clutch" you will have to buy it, install it and then HOPE it works out. How much will it cost you to roll the dice??? You might not be happy with the new clutch. Now you are much more in the hole.
There might be some loss trading your car for an automatic but what you loose on the trade in will be partially offset by not paying for this new clutch....that may, or may not even work out. I would suggest just cut your losses and get a nicer one with the paddles. |
![]() Drives: 2013 1ss Join Date: Jul 2012
Have you tried finding good physical therapy for range of motion and strength? Over the years I have had great results with getting a proper stretching and exercise routine for knee issues.
Like most things it depends on finding the right therapist. |
#5 | |
I have excellent range of motion and strength, I walk up to 15 miles per day at work, including lots of stairs. The cartiledge is worn thin and my knee cap tracks poorly. 🤢 The problem is, I love the manual and wouldnt have much fun in an automatic. I guess option 3 is buying a commuter, but that's the camaro's job. I can and will do all of the labor myself, it's a pretty easy job. But you're right, spending $1400-2500 on a clutch that doesnt work out won't save me any money, not to mention the resale value loss if the car is modified at all. I know I'd assume it's been beaten.
#6 |
![]() Drives: 2015 2ss Join Date: Jun 2009
i have the RST clutch, the pedal is almost lighter than the OEM clutch. but that was until i put in the Tick Performance Master Cylinder to resolve my clutch pedal sometimes sinking to the floor.
![]() 2015 Camaro 2ss, NicKey Performance built/tuned |
#7 |
![]() ![]() Drives: 2014 1SS/1LE Join Date: Nov 2015
Have you removed the "helper" spring at the top of the clutch pedal?
#8 |
GPI Sales Consultant
If you can get your hands on an Ideal Garage modified clutch master cylinder you might really like that. They pop up once and a while used, unfortunately they are no longer in production. It's a stock master that's been bored and ported to flow more volume. Made my clutch pedal very high and fully actuate the clutch in less than half the pedal throw. I recommend using a pedal stop, as you have the potential to over-travel the clutch which it won't like. I'm not sure, but I ran mine for the last 4 years without a pedal stop and have chewed up two throw out bearings, the second one having the billet support. I'm finally adding the clutch stop, and going to a Tilton master - enough is enough. One of those with a nice triple disc would be very light, and very little travel.
Got a question about a GPI product? Feel free to shoot me a message! |
#9 |
I haven't, does it seem to help reduce pedal effort? I guess half of my issue is the LONG non adjustable pedal travel, on my other car (240z) the clutch pedal is adjusted 1/2-2/3 as high as stock and still works well. If I can get it to be fuctional with a low pedal, and just burnout my ankle instead of the knee, I could probably get a lot more miles out of this.
#10 | |
Sent from my Pixel XL using Tapatalk
#11 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
2009-2010 ZR1 clutch.
#12 |
![]() Drives: 2014 1ss camaro Join Date: Jul 2017
not being a smart ass when I say this, because I did it. I was having knee problems for years. I got a total knee replacement. one of the best things I ever did. no more pain and the clutch feels fine.
#13 | |
I blew out my knee back in the 80s. I have had it cobbled back together twice. Both surgeons said they wouldn't do the replacement surgery until I was in my 60s. Average replacements have to be redone every 10-15 years. My first surgery lasted 23 years and I'm at 14 on the second one. For reference, list of damage done to my knee. Broke femur, tibia, fibula and patella, severed the PCL, ACL, MCL and LCL ligaments, tore both meniscus cups (original surgeon scooped them out with a spoon). Damage result of 10cm posterior dislocation with 180° rotation. ER doctors were drawing a dotted line just above my knee where they were planning on amputating my leg. Good thing my family doctor was a very well known doctor in the area and the team doctor for the CA Angels. And he knew the primary knee surgeon at Kerlan-Jobe Orthopedic Clinic in LA. My reconstructive surgery took 7.5 hours and 2 years of rehabilitation before I could walk without assistance. What I am saying is knee replacement isn't always the answer. |
#14 |
I'll be 31 next month, I've got a long way to go before knee surgery, I am just trying to buy time for now...
