Old 06-20-2010, 08:28 PM   #1
jordan 572
jordan 572's Avatar
Drives: none
Can I use 5w-20????
Can I? I already have it.
jordan 572 is offline   Reply With Quote
Old 06-20-2010, 09:34 PM   #2
jehartley
jehartley's Avatar
Drives: Red LT1 & Silver LS3
Can you? Yes. Should you? No.
For warranty concerns, your owners manual is very specific: 5w30 unless you live in a particular climate (your manual will say the temp) that allows for 0w30.
jehartley is offline   Reply With Quote
Old 06-21-2010, 07:30 AM   #3
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
No. You need to run <something>-W-30 (depending on the temps in your area).
Old 06-21-2010, 08:29 AM   #4
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Don't do it.
The operating viscosity of 5w-20 is worse then the operating viscosity of 5w-30. Once the car gets up to running temperature you will only be causing damage to the engine due to less lubrication.
Old 06-21-2010, 12:39 PM   #5
wylde1
I am the Stig
wylde1's Avatar
Drives: Black w/ IOM stripe 1SS
absolutely not
the bearing clearances are designed around the size of the hydrodynamic wedge created by the operating viscosity of SAE 30 rated oil. Using 20 will change the wedge size/shape and ruin your bearings.
2010 Camaro - 1SS, Black w/ Orange stripes
wylde1 is offline   Reply With Quote
