11-05-2021, 05:55 PM | #1 | |
Drives: 2010 SS L99 Join Date: Sep 2018
Weird occurence for the 2nd time
This has happened twice in the last 6 months. The starter was heat soaked and started really hard, then the tach wouldn't work at all, it stayed at zero, and all the lights on the dash (stabilitrak and the others) came on, and the car had an abnormal lope. Not the usual chop but different, like a bit more natural sounding lopey cam idle. Anyone ever have this happen? Just wondering what the reason could be.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
11-05-2021, 06:37 PM | #2 |
Drives: 2010 IOM 2ss/RS Join Date: Sep 2009
https://www.camaro5.com/forums/showthread.php?t=504199
look here, there are many other threads in the same subsection
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
11-06-2021, 07:31 AM | #3 |
Drives: 2015 1LE Join Date: Oct 2015
Battery probably getting ready to take a shit. On GM cars a lot of time if there is a voltage issue the dash will flip out.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
11-06-2021, 08:17 AM | #4 |
Drives: 2013 L99 Join Date: Jan 2019
Your battery is going on hospice
11-06-2021, 10:38 AM | #5 |
yeah, could be battery, could be much more involved...start with the battery though.
11-06-2021, 10:56 AM | #6 |
Before guessing/getting a new battery get a cheap $15 battery analyzer and do a load test. That’ll tell you how many volts your battery is producing. Do once before first start of day then again after car is really heated.
11-06-2021, 01:01 PM | #7 |
Thanks guys. I just replaced the battery 2 years ago, too. Then last year both the alternator and the starter. Went with OEM for those.
11-07-2021, 01:45 AM | #8 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I have had batteries die on me only after a couple years. Especially if you have a walmart or o'reilly battery.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
11-07-2021, 09:32 AM | #9 |
When my battery went bad it did all that funky crap too. Replaced it with OEM, and that one only lasted about 1.5 years and took a dump too, it was bad from the get go, got it replaced under warranty and been good so far. It's not the first time I have had a battery just decide to quit. Good luck.
11-07-2021, 11:48 AM | #10 |
If this one is bad I am going to say screw it and just get a Braille lightweight battery like I wanted in the first place. I'll get it figured out and post the fix when I can. Again, thanks everyone
11-07-2021, 05:30 PM | #11 |
Well if it ends up being a battery, the Optima's usually last a really long time. Also check the grounds, I think BoWhite had a ground issue that caused cranking problems, he cleaned up some contacts in the trunk with the battery cable on the chassis I think and it fixed it. Might ask him about it.
11-07-2021, 06:39 PM | #12 |
I have had this exact same thing on my old battery. It was before I cammed it and remember I let it run for a minute or so since it sounded kinda cool. I didn't replace my battery right away, but I know it had happened a few times. Usually turning it off and back on again cleared it and the tach and idle would go back to normal.
11-07-2021, 09:33 PM | #13 |
it drops the sensor for the crankshaft position. probably not the best for the engine...it'll run, but timing etc is off.
11-17-2021, 05:54 AM | #14 |
was this resolved?
