Old 10-24-2020, 05:29 PM   #1
Whitlow
Whitlow's Avatar
Drives: Chevrolet Camaro
ANYONE KNOW WHAT THIS IS FOR??
So I opened my fues box and saw this. A jumper wire for something. My car is a 2012 SLP585 6SPD. I tried to take a picture of the wires it goes into.
Thanks
Sent from my motorola edge using Tapatalk
Whitlow is offline   Reply With Quote
Old 10-24-2020, 06:35 PM   #2
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Just guessing but maybe a power lead for heat exchanger pump if you have one.
HOJO is offline   Reply With Quote
Old 10-24-2020, 08:51 PM   #3
Vegas Bound
Drives: 2013 Sparkly Red One
Follow it.
Lots of bolt on stuff
Bests in each category
1.36 - 60'
6.29 - 1/8 mile
10.18 - 1/4 mile
Vegas Bound is offline   Reply With Quote
Old 10-24-2020, 09:33 PM   #4
Whitlow
Whitlow's Avatar
I did but with it a wiring diagram I'm lost thought maybe someone else has this.
Old 10-25-2020, 12:17 AM   #5
PeteD
PeteD's Avatar
Drives: 2012 2SS Victory Red with white st
It is def. aftermarket. So the previous owner added it or the people at SLP did. Probably no wiring diagram for it. SO, follow it as stated above.
PeteD is offline   Reply With Quote
Old 10-25-2020, 06:41 AM   #6
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
Its a Power Source for the Flux Capacitor
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28)
2009 Pontiac G8 3.6L the DD
102SS is offline   Reply With Quote
Old 10-25-2020, 07:47 AM   #7
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
What HOJO said
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 10-25-2020, 08:58 AM   #8
xc_SS/RS
Drives: 2010 Camaro SS/RS
i think HOJO is correct. May also be for the halos to stay on all the time when its running
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 10-25-2020, 09:11 AM   #9
Kajun
Kajun's Avatar
Drives: 2013 1SS L99
Looks like it's power for the fuse holder and relay taped together in your picture. Looks aftermarket to me.
2013 1SS/RS L99-GPI VVT SS1 - TSP 1 7/8 headers with high flow cats and Borla S-Type Cat Back - Z/28 CAI - 1" BMR lowering springs - BMR toe rods and trailing arms - Prothane rear cradle bushings - ADM trans cooler - Yank 3400 Stall - Tune By Futral Motorsports
Kajun is offline   Reply With Quote
Old 10-25-2020, 11:12 AM   #10
skip_168
idiot-genius
skip_168's Avatar
Drives: 2014 SS
disconnect it and see what screws up...
skip_168 is offline   Reply With Quote
Old 10-25-2020, 12:23 PM   #11
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Thats the best option if you cannot trace it. The original owner may have removed something and just left the wire in there instead of removing it.
Mods - GPI Tune (Rhino79), SS2VVT Cam & RodMod Intake, CHE Trunion Upgrade, Holley Fuel Rails, B&M Transmission Pan, JRE Trans Dipstick, Circle D 3600 Single Disc Converter, ADM CAI, Scoop & Trans Cooler, Kooks Headers & Cats, Solo Cat Back, Elite Catch Can, Z28 Grill, Aero & Body Package, BMR 1" Lowering Springs & all the BMR Goodies in the rear, Hendricks Offset Diff Bushings, AFE Solid Subframe Bushings, MRR228 Wheels, Eaton Tru-Trac, Hurst Roll Control.
Ashen 6.2 is offline   Reply With Quote
Old 10-25-2020, 12:59 PM   #12
sean_reaves33
Drives: 2011 camero ss
I do have one different color thats disconnected, just hangs there.
Sent from my SM-G965U using Tapatalk
sean_reaves33 is offline   Reply With Quote
Old 10-25-2020, 01:00 PM   #13
sean_reaves33
I agree
Old 10-25-2020, 04:13 PM   #14
Whitlow
Whitlow's Avatar
It's not connected to anything right now it is a female connection. It goes into the harness with the 2 connectors as you can see in one of the pictures.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
