03-03-2020, 08:29 AM | #1 |
400HP used to be enough..
Drives: 2010 2SS rs manual Join Date: Aug 2009
Boost Controller recommendations
I'm probably going to install a boost controller on the Huron Speed twin kit I have. For the people who have done this, did you use one solenoid or two? I think there are advantages to doing it either way, I'm just curious what has worked for other people.
Build thread: http://www.camaro5.com/forums/showthread.php?t=47925
03-03-2020, 09:01 AM | #2 |
Drives: G8 Join Date: Mar 2012
I use a single solenoid GFB3 on a twin kit. No complaints here
Sent from my Pixel 4 XL using Tapatalk |
03-03-2020, 09:47 AM | #3 |
Drives: Black 2SS RS w/White Stripes Join Date: Mar 2011
Dido!
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods | Installed by Me & Tuned by Pat G |
03-03-2020, 10:35 AM | #4 |
Drives: 2015 Camaro SS commemorative Join Date: May 2015
AEM TruBoost is common and affordable. Single port and uses a standard PWM type signal.
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
03-03-2020, 12:01 PM | #5 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
A single solenoid may get you about 2x the wastegate spring in boost (e.g., you have an 8# spring, you may get up to 16# boost with the EBC). This is generally fine with a SBE LS3/L99 setup.
A dual solenoid may get up 3-4x the wastegate spring. You will loose precise adjustments when getting high in boost, like adjusting a few WG duty cycle point may get you a larger swing in boost.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
03-03-2020, 12:57 PM | #6 |
Dual solenoid eBoost2, love it.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM |
03-03-2020, 02:01 PM | #7 |
Trouble_SM
Drives: 17' Summit White ZL1 Join Date: Jan 2015
Boostleash pulse controller with built in bump feature. It also data logs each run and shows boost throughout the run.
03-04-2020, 08:17 AM | #8 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
good stuff here guys. Thanks for all the different responses.
03-04-2020, 09:24 AM | #9 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
I was using the built in boost controller on ms3. It's a total pos so I'm switching to the boost leash. I'm using co2 as well. Highly recommend using it
03-04-2020, 01:13 PM | #10 |
Drives: T Join Date: Mar 2015
Im on aem tru boost, its really simple and has a scramble option, open loop style controller.
If i could do it over again i'd get an Eboost 2, just to play with boost by gear. |
03-04-2020, 09:55 PM | #11 |
I have the AEM TruBoost currently. Really like it for as simple as it is and use both boost settings A and B, plus have the Scramble hooked up. Overboost protection works well. Easy to program right on the gauge.
Recently I purchased a Cortez. It has a lot of bells and whistles including boost by gear and can control meth, nitrous, secondary fuel pumps, and/or do scramble. I haven't had time to swap out controllers just yet. Expecting it to be really groovy.
03-05-2020, 07:59 AM | #12 |
Thanks for all the responses, everyone. I appreciate the help.
Frank
04-21-2020, 12:30 PM | #13 | |
Drives: 2010 Camaro SS/RS Twin Turbo LSX454 Join Date: Aug 2018
I've been looking at getting a Cortez unit as well but I know very little (nothing) about boost controllers. Can you expand a little on why you decided to go with the Cortez unit? When you get around to installing in please do post. I'd love to have a walk-through of sorts from a Camaro owners pov. |
08-01-2020, 10:14 AM | #14 |
Drives: 2011 Camaro SS Join Date: Jul 2017
I'm installing my EBC this weekend. Where are you guys mounting the solenoid? My turbo kit is the Huron single kit.
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
