Old 09-04-2019, 03:27 PM   #1
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
LS7
Picked up a hurt LS7 Out of a Z/28 dont know if the block is salvageable or not, cam is stock in the block do to a lifter not coming out, will get it on a stand soon and see how bad it is, hope i can save the block.
Old 09-04-2019, 07:29 PM   #2
Gbland60
Gbland60's Avatar
Drives: 2015 z28 Black w/ac #645
When you say hurt you mean like what mains, rods, dropped valve, broken cam ?
Gbland60 is offline   Reply With Quote
Old 09-04-2019, 07:35 PM   #3
69L48Z27
69L48Z27's Avatar
Drives: 2015 Z/28; 1969 Camaro SS
Post what VIN is on the engine if you don’t mind. See if it belongs to one of the cars in the salvage thread.
69L48Z27 is offline   Reply With Quote
Old 09-04-2019, 10:36 PM   #4
2SSRS@Gen5diy
No more like a roller lifter, that needs to come out and will not.
It's not out of a salvaged car, I know the car it came out of, and if the owner does not want me to say then I will not.
It may need a block when I get some time I will find out.
Old 09-05-2019, 01:58 PM   #5
2SSRS@Gen5diy
So two sets of two lifters are stock, one goes up far so i can move the cam forward but the second set will not move up for the cam to move forward, time for the BMH, ned to get that lifter up out of the way.
Old 09-05-2019, 04:04 PM   #6
Gbland60
Gbland60's Avatar
Got ya. Maybe you can sleeve the bores once its out. IDK but good luck on the project build. Sounds like fun
Old 09-10-2019, 02:16 PM   #7
Russell James
Russell James's Avatar
Cams fracture pretty easy with sharp blows. Might be able to get a big punch in there are break the cam up. If you can get the cam pieces out, shove the stuck lifters out the bottom. I got lucky doing that once with a BBC that had mushroom'd out a lifter. Then had the lifter bores bronze bushed.
Old 09-27-2019, 03:12 PM   #8
2SSRS@Gen5diy
Today we worked on the LS7 cut off the lifter ( there comp lifters and come as a set of 2) and where able to remove the cam, that was not fun, needs cam bearings there done, needs Cam and lifters to, now to get the block redone.
Old 09-28-2019, 02:16 PM   #9
2SSRS@Gen5diy
Today we pulled the pan and windage tray, think this motor had some oiling problums, front of crank is blue like it got hot, rear is fine, will post pic's later this coming week, got to talk with the prior owner.
Old 09-29-2019, 07:02 AM   #10
ronchev
ronchev's Avatar
Drives: 14' Red Z/28 #336
Ofer post up some pictures of this if you can, sure would like to see what you are dealing with on the problems this engine had. I am pretty sure I know some of the background of this engine and am curious. Thanks
ronchev is offline   Reply With Quote
Old 10-02-2019, 04:11 PM   #11
2SSRS@Gen5diy
So i was wrong on the motor over heating it a coating GM put's the crank, its a different color on machined surfaces, and looked like the crank got hot, it did not.
I have some pics to share, i will let them do all the talking.
Old 10-02-2019, 04:17 PM   #12
2SSRS@Gen5diy
I will leave this pic here so you can see the damage to the lifter bore.
Old 10-02-2019, 04:42 PM   #13
MrRaZ28
@MrRaZ28
MrRaZ28's Avatar
Drives: 2014 Z28 #80
Wow... that's... um.. not good. Ouch!
MrRaZ28 is offline   Reply With Quote
Old 10-03-2019, 07:44 AM   #14
ronchev
ronchev's Avatar
Thanks for posting these pics, was wondering how bad the lifter bore looked.
Is this a comp cams lifter?
Good luck on getting this back in shape, looks doable from the picture you posted.
