09-14-2023, 08:41 PM | #1 |
Drives: 15 ZL1, 20 6.2 Trailboss Join Date: Jun 2021
Chirping noise with belts removed... :( 2015 zl1
Has anyone heard this noise before? Sounds like its something in the passenger side valve train... I removed the belts just in case it was a pulley, which unfortunately wasn't the case.
Any ideas? Stock internals. https://youtube.com/shorts/TuAcIYFLo...zFDheFfGci1l9Z |
09-14-2023, 10:17 PM | #2 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
Where is the vid without the belts.
09-15-2023, 05:06 AM | #3 |
This video was taken prior to removing them. The noise was still there after.
09-15-2023, 06:21 AM | #4 |
09-15-2023, 07:21 AM | #5 |
M6.
09-15-2023, 08:31 AM | #6 |
Hows the clutch? Also you can buy an inexpensive stethoscope at advance Auto parts , or any of the big chains including Walmart I believe. That will help you target in the motor area. I have not heard that sound on these cars but the video doesn't give me any direction as If I was standing there. Since you are standing there it should be pretty simple to target the area of noise. I asked about the clutch because I have heard a similar sound when the clutch was really bad as the disk rattle when reving the motor. |
09-15-2023, 08:43 AM | #7 | |
The sound is somewhere in the passenger side head/header connection area near the firewall. When i get home later, i will get underneath and check exhaust connections and heat shields. Doesn't sound like any exhaust leak I have ever heard but worth a shot? |
09-15-2023, 11:41 AM | #8 |
Drives: 2010 2SS/RS A6 Join Date: May 2019
Some part loosened and resonated
09-15-2023, 03:54 PM | #9 |
That's a bingo! Were the headers about to fall off? (Not really but really) yeah they were! What a nightmare of i shop i took it to. Scratched the bumper, never torqued headers, made a mess of the wiring under the hood, hacked up the ice box install... I guess thats what a loose header sounds like. Thanks for all the input guys.
09-15-2023, 05:07 PM | #10 | |
20lbs on the header bolts, and yes the sound would go away if you depressed the clutch pedal as the clutch disk would stop spinning. |
09-15-2023, 05:22 PM | #11 |
Glad you found it! But crap man, that shop wouldn't see me anymore!!
09-15-2023, 11:22 PM | #12 |
