09-28-2012, 09:04 PM | #1 |
Drives: 2013 2ss/rs A6 yellow !!!!! Join Date: Nov 2011
160 thermostat
What are everyones opinions and experiences with switching too a 160 stat? Also wont the viscosity suffer slightly and what about moisture buildup in cooler temps in fall winter?
09-28-2012, 11:39 PM | #2 |
Sarcasm loading --------
it will just take longer to get to operating temperature. unless you upgrade the radiator, it will run the same temperature. stock temp is already 185.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
09-29-2012, 06:36 AM | #3 |
Drives: 2011 Black SS M6 Join Date: Oct 2010
I asked this question to a well known engine builder and I was told that it's not a good idea to drop a 160 thermostat in the car. The tolerances are such with these motors that it must get to the proper operating temperature for the engine to run right. I also recall an enitre thread on this topic and the same conclusion was reached.
09-29-2012, 07:05 AM | #4 | |
Perpetual Order
Drives: indeed Join Date: Jun 2012
09-29-2012, 07:23 AM | #5 | |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
My first mod was kooks headers, chokemaster 3" catback with center mount exhaust, 160 stat, VARARAM and tuned.
09-29-2012, 09:42 AM | #6 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Right so these cars will never actually sit at 160F with the stock water pump, that is a fact. Folks who have one should post what their lowest temps are at idle and and cruising.
I will do one for next year, my car won't cool lower than 194 idling in the staging lanes and I want mid to high 180's. My car will sometimes get to the high 180's at cruise. And I'd like to hear from someone who has one and what their temps are when it's freezing out.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
09-29-2012, 10:17 AM | #7 |
Drives: none Join Date: Aug 2011
idling mine runs up to 203 before the fans kick on
75mph on the interstate and it'll hover in the mid 170's, unless it's 100+ degrees ambient then it sits around 180 I think I'm going to eventually upgrade to 2 bar in HPT so that I can control the fans at lower temps than the stock OS allows |
09-29-2012, 10:29 AM | #8 |
TRI-COUNTY CAMARO... FTW!
Drives: 2010 Camaro 2SS M6 Cyber Grey Join Date: May 2010
I wouldn't do it, and haven't done it. My shop advised against it, and one of the more respected builders on this sit, Jannety, said that they do more harm than good.
CAI inc. cold air intake, LG G6x3 cam, Patriot Gold Extreme Dual springs, Titanium retainers and locks, LG SuperPro 1 7/8 Long Tube headers with full 3" exhaust, DynoMax VT mufflers, SLP 4" tips, Moroso catch can, Race Ready electronic exhaust cut outs, Full painted Razzi body kit, Headlight Armor Smoke taillight and marker blackouts, T-Rex aluminum upper and lower grille, Polished aluminum front and rear bowties. Professionally installed and Dyno Tuned by HorsePower Sales, Pompano Beach FL.
09-29-2012, 10:36 AM | #9 | |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
09-29-2012, 01:03 PM | #10 |
Perpetual Order
160 degree thermostat will run between 180 and 195, never even needing the fans to kick on and this is in 100 degree texas summer. just ime.
09-29-2012, 06:15 PM | #11 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
See I never saw the benefit of running a lower thermostat on anything but a fully built engine...or if you're in extremely hot climates. And these cars do well even in extremely hot climates. I mean, if your engine is running in the normal temps, then everything is fine and there is no need for a colder stat. If your engine is overheating, then there is something wrong that needs to be fixed. It just seems like a useless modification.
09-29-2012, 06:37 PM | #12 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
this is a huge debate. Top shops in the north say stock. Top shops in the south say 160. I think everyone can figure out why. BTW I run a 160 and I dont think I have ever seen past 195. We get 110 degree temps here.
09-29-2012, 06:38 PM | #13 |
Drives: 2015 c7 Join Date: Nov 2009
09-29-2012, 07:22 PM | #14 |
I'm in south Florida.... None of the big shops use them. Just saying. Not just my opinion, but that of 4 of the most reputable shops in all of south Florida.
