01-05-2019, 05:27 PM | #1 |
Drives: '23 LT1 A10 Join Date: Oct 2015
AC compressor bad or just the o-rings?
Well it's been cold out recently so I haven't been running the AC. Today I turned it on because it was warm out and I can hear the AC hissing from the dash. My knowledge tells me this is a low freeon issue and I can feel the AC isn't that cold. I pop the hood and see the compressor is barely staying on. I look at the AC lines going into the compressor and see it's leaking. I'm wondering if I should replace the entire compressor or if I can get away with just replacing the o-rings?
Thoughts?
24 LT1 M6 Sharkskin Metallic
01-07-2019, 09:26 AM | #2 |
Drives: 2010 SS Camaro Join Date: Oct 2008
O Rings only. Put a little oil in it as well to replace what has leaked out
01-07-2019, 08:39 PM | #3 |
Replaced them today and had a shop vac and charge. I'm wondering why this failed at 45k miles.
01-07-2019, 09:06 PM | #4 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Things happen.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
01-07-2019, 09:42 PM | #5 | |
Drives: Miss Con Ception Join Date: Aug 2016
Isn't Texas famous for, "It's hot, but it's a dry heat."? That, plus the BS, "We have to make parts out of cornstarch to save the environment."
2011 1SS/RS LS3 CGM
01-07-2019, 10:21 PM | #6 |
Yeah I guess. Just sucks. I am hoping the shop added enough freon. I heard the compressor cycling more than I remember it prior.
