11-04-2018, 07:57 PM | #1 |
Drives: 2011 Camaro SS Join Date: Feb 2017
ZL1 Fuel Pump Question
I have a 2011 SS A6 with tsp stage 3 cam, LT headers, CAI, 3200 stall and 3.91 gear. Going to install 100 to 150 shot of nitrous. Getting a ZL1 pump to up the fuel pressure, is it just plug and play or do I need other components? Or tune?
MRR M228 Wheels, Circle D 3200 Stall, 3.91 Gear, Texas Speed VVT 3.2 Cam, CHE Rocker Arm Bushings, Texas Speed Headers, No Cats |
11-05-2018, 07:54 AM | #2 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
The stock SS Fuel Pump Control Module is programmed to let fuel pressure fall off as the rpms rise. Here's a pic. Second pic is the ZL1 fuel pump control module tune. It keeps pressure the same at all times.
So, while a ZL1 pump can flow more, you should either modify your stock SS FPCM (using HPTuners, like I did) or buy an already modified FPCM from a vendor who sells them and then get a tune.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
11-05-2018, 08:13 AM | #3 |
Drives: 2019 Corvette ZR1 Join Date: May 2017
As mentioned, you'll want to edit the FPCM to get more out of it. The other option is to just buy a ZL1 FPCM, but it is a lot cheaper to just edit the module.
11-05-2018, 09:19 AM | #4 |
Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
You’re going to need a tune. I also got zl1 injectors, and an ADM FPCM along with the fuel pump when I had my flex fuel sensor installed.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
11-06-2018, 06:55 PM | #5 | |
11-06-2018, 08:38 PM | #6 |
Drives: 2010 Camaro 2SS LS3 Join Date: May 2012
Tuner to edit the stock FPCM, will give you up to 58psi right now at WOT. Then if you feel you still need more flow, get a ZL1 pump.
11-06-2018, 09:13 PM | #7 | |
Thats my current setup now, with DW90# injectors and a bap. But the DSX Aux pump should be here anyday, then I’m going e85.
11-07-2018, 09:47 PM | #8 | |
