11-16-2015, 04:01 PM | #1 |
KaBoom1701
ZL1 Brake bleed gone bad....
Well this was a fun weekend.
So in preparation for the up coming track day at Chuckwalla I decided to change the fluids I'm my ZL to get her ready. Oil change good. Clutch fluid reservoir fluid swap went well. Manual tranny fluid change went well. Brake bleeding was going well until I was on the last caliper (front right) outside bleeder valve and snap...I barely touched it and the top half of the value snapped off...I almost crapped me pants....couldn't believe it. Best I could tell is that when I first bought the car I took into my local Chevy dealer and had them do a full DOT3 to Motul DOT4 for me. I guess the tech really tightened the last valve down hard. I wouldn't budge. I tried to use an extractor and that broke off inside the valve. Tried drill that out and it almost seemed the valve was cross threaded. I did take the caliper off and go to a buddies (mechanic) house and he was able to get the replacement valve I bought to thread but after bolting everything back on a pressurizing the system there was a small leak....bummer. So I'm out $1000 to buy a new front right caliper. This is turning out to be the most expensive brake bleeder project ever. lol
Mods:
11-16-2015, 05:29 PM | #2 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
ouch..
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
11-16-2015, 05:32 PM | #3 |
Drives: 2017 Jaguar F Type R Tuned 498awhp Join Date: Apr 2013
$1000 ?????? Amazon.com its like $300
JRE cammed w.full bolt ons 444rwhp/422rwtq SOLD
2017 Jaguar F Type R ''Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.'' - F. Bueller |
11-16-2015, 05:51 PM | #4 |
KaBoom1701
I saw a few front left calipers but no front right ones.....
I did get your PM's and I'll check out those options. Thx
Mods:
11-16-2015, 06:51 PM | #5 |
Go fast, please.
You could probably use an easy out or something on it and just remove the screw and replace it instead of the whole caliper.
11-16-2015, 06:57 PM | #6 | |
KaBoom1701
Trust me. We tried for almost 6 hours to save the caliper.... On an interesting note. There are several front left ZL1 calipers on eBay or amazon but the front right are no where to be found. I called a few sellers and they said it's because when people wreak these ZL1's the swerve off the road to the right .....damaging the whole right side most of the time. Just some FYI.
Mods:
11-16-2015, 07:08 PM | #7 | |
Go fast, please.
lol that's funny. That valve must have really been stuck... I have been contemplating doing the same thing, mostly for adding a separate clutch fill... How hard was the clutch to bleed? I've read that bleeder valve is a pita. |
11-16-2015, 07:47 PM | #8 |
Drives: '21 ZLE A10 Join Date: May 2012
damn...cut a slot in the top of the bleeder and use a screwdriver and turn it out. Put a little heat on it too...done. Sorry, bleeders in general are soft metal and are prone to breaking.
11-16-2015, 09:14 PM | #9 |
Jersey Jeff
Drives: 1969 Camaro L89/T400 ~ 2015 ZL1 Join Date: May 2011
"Nothing is easy". My favorite saying. I don't care what you're doing, nothing is easy. I don't care if it's changing the belts on the riding mower, it's always turns out something bites you in the ass.
JerseyJeff |
11-16-2015, 09:23 PM | #10 |
Drives: 2015 Red Rock ZL1 Join Date: Dec 2014
Isn't that the truth, Murphy's Law...
Alex
2015 Red Rock ZL1 Panama City Beach, FL |
11-16-2015, 09:35 PM | #11 |
Go fast, please.
Did you bleed the clutch line or just swap it over?
11-16-2015, 09:36 PM | #12 |
BUMBL Z
Damn... That's a real smack in the face. You try gmpartsdirect with a part number? I can't imagine a single caliper running a grand, ZL1 or not
Current: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower w/ Idler Relocation, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, Tuned by Pat G
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq |
11-16-2015, 10:15 PM | #13 | |||
KaBoom1701
I just swapped the fluid in the separate clutch reservoir. Haven't had the courage to try to installed the tick bleed yet. Quote:
I did try GM parts direct and other sites. Part number: 20944530 http://www.gmpartsdirect.com/oe-gm/20944530
Mods:
11-16-2015, 11:40 PM | #14 |
BUMBL Z
Ouch. You see if Becky at Rodgers could get you a better price?
