#Camaro6
Go Back   CAMARO6 > CAMARO6.com General Forums > 6th gen Camaro vs...
Old 12-02-2015, 09:26 AM   #1
DevonK
DevonK's Avatar
Drives: TBD
C7 reliability - a heads up for the Gen 6??
Car and Driver just put up their long-term wrapup on their C7 - and to say it is scary is a gross understatement. I probably would have lemon-lawed the car it had so many issues. Everything from the HU down gave them headaches - grenading engine, leaking axle seals at 25k, crappy transmission that had no fix, failed HVAC, the list goes on. Now their car may have been an extreme example but the Vette forums suggest problems are not uncommon.
It will be very interesting to see if the same reliability issues plague the Gen 6 - it of course has basically the same engine, but the car itself is assembled at a different plant from the Vette so maybe there's hope.
DevonK is offline   Reply With Quote
Old 12-02-2015, 09:35 AM   #2
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Drives: 2017 Chevrolet Camaro SS 1LE
Supposedly there was a bad batch of engines that had some metal shavings from bad oil filters if I recall, theirs was one of those. I know three people with C7's, a '14, a '15 and a '16, no issues like these so far. Their transmission issues only started after the new engine was installed. If that was me, I would have demanded a resolution, as it was fine beforehand. The axle seals were from the extreme cold, guess GM thought nobody drives Vettes in snow and freezing temps LOL. But they have different axle seals now on all C7's.
SS 1LE is offline   Reply With Quote
Old 12-02-2015, 09:46 AM   #3
DevonK
DevonK's Avatar
Drives: TBD
The oil filter was not the only engine issue:
GM acknowledged that the engine manufacturing plant had experienced some difficulty ridding the inside of the block of machining burrs. As luck would have it, its oil-filter manufacturer had a similar problem; some filters had a thread shard that could come loose and contaminate the lubrication system.
The tranny's issues don't seem directly related to the engine - it simply can't cope with cold weather (and having a 7th gear was a big mistake too from all accounts). And the starter motor burned out as it was taking 12 seconds to start the car in the cold - did GM do any cold weather testing on this thing?
Old 12-08-2015, 08:45 PM   #4
joelster
joelster's Avatar
Drives: '94 Z28+ '15 Z/28
All 3 car magazines, Motor Trend, Car and Driver, and Road and Track or Automobile, had issues. Big issues. Ask Randy Pobst what it's like to run a Z06 at full boogie? Oh that's right, he can't get one to do a full lap without pulling boost on the stick cars or going into limp mode on the auto.
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C
1980 Z28- resto-mod project
1979 Y84 Trans Am
1986 IROC-Z
joelster is offline   Reply With Quote
Old 12-08-2015, 10:44 PM   #5
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Heat issues on these Z06 cars....
Mods:
Old 12-13-2015, 08:21 AM   #6
JBsC6
Drives: 2008 Blk C6 Z51 NPP
Where do you guys come up with this.
Percentage wise the c7 is among the most reliable vehicles.
The 500 mile oil change resolved the gasket bleed off that was contaminating the oil at the track...
The solution was to change the oil at 500 miles and remove the contaminants the gaskets were putting out in the first 500 miles.
I hope that clears up the reliability aspect of the LT1.
It's a hell of a mass produced engine.
Remember the c7 z51 is warrantied even with track use....
Most manufacturers will void the Warranty if you take their car to the track.
That's pretty cool of gm ...
2008 Blk C6 Z51 NPP M6/2008 Silver CTS AWD FE2 304hp
JBsC6 is offline   Reply With Quote
Old 12-13-2015, 03:45 PM   #7
mcsoul
Drives: Want a gen 6
I suspect revisions and latest tech wise, the 2016 Camaro drivetrain is more comprable to the 2016 c7 than the 2014.
mcsoul is offline   Reply With Quote
Old 12-13-2015, 06:46 PM   #8
mako22
mako22's Avatar
Drives: 2017 HB 2SS
mako22 is offline   Reply With Quote
Old 12-14-2015, 03:47 PM   #9
SS376
SS376's Avatar
Drives: 2013 1SS LS3
It's not just Corvettes. Check out the truck and SUV forums. Lots of issues. I wouldn't even consider a gen 6 until I see how the first year shakes out. People can pretend everything's fine, but GM QC really seems to have slipped recently.
SS376 is offline   Reply With Quote
Old 12-14-2015, 04:54 PM   #10
LesserO2Evils
GM repeat offender...
Drives: 16 2SS
BAD news is still, news. We would be foolhearted to ignore possible issues. Dont flame the poster.
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15
INCOMING: ‘22 ZL1, Satin Steel. A10. PDR.
Ordered: 03/02/22.
LesserO2Evils is offline   Reply With Quote
Old 12-14-2015, 06:27 PM   #11
stratosphere
stratosphere's Avatar
Drives: 2015 Stingray & 2011 Cruze
My C7 has been a dream, nothing like the problems C&D had.
stratosphere is offline   Reply With Quote
Old 12-14-2015, 10:26 PM   #12
IOMike
Drives: 2022 F150, 87 Monte Carlo
I have heard of little to basically no powertrain issues in the new GM trucks. Some have had vibration issues (not engine vibrations) and many complained about the slow throttle response (tuning for gas mileage) but those are irrelevant.
IOMike is offline   Reply With Quote
Old 12-14-2015, 10:29 PM   #13
IOMike
Yeah, because car and driver didn't put that car into the wall a few days before. It was discovered that the intercooler pump wiring wasn't fully secured which is why the car was running hot. Before Car and Driver put it into the wall it set the record on the track it was running on.
Old 12-15-2015, 06:48 AM   #14
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
People keep forgetting about all the great lap times the Z06 has been laying down and concentrating on the the snafus. People will be people and man's best friend will always be his dog...for a reason.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
